Old 05-30-2019, 11:52 PM
evs evs is offline
Default running ultimate and normal on one machine
hi,
a friend has the normal Pro Tools vesrion running, and would like to, from time to time, use the HD Ultimate version as a subscription on a monthly basis.
Now the avid support says that you can not run ultimate and the normal version on one computer...
is that right?
couldn´t you make up a second account and put it there?
thanks!
Old 05-31-2019, 12:17 AM
jeffro's Avatar
jeffro jeffro is offline
Default Re: running ultimate and normal on one machine
This is controlled by the license, so simply activate the one you want to run on your iLok using iLok License Manager.
linkedin
Old 05-31-2019, 02:51 AM
evs evs is offline
so no different driver that will crash the other version when installed?
Old 05-31-2019, 03:02 AM
Driver for what? Are you expecting to work with DigiLink interfaces?
Otherwise should will be fine.... Standard cannot use any DigiLink interfaces. And you cannot run both versions simultaneously... besides that no problems, and I have no idea what Avid support person was thinking.
Old 05-31-2019, 03:30 AM
JFreak's Avatar
JFreak JFreak is online now
PT standard and PT ultimate are the same software. If you have the Ultimate/HD license available on when you boot, you get full features. And you cannot choose to run with standard features when you have Ultimate/HD license. Clear enough? If you want to downgrade all you need to do is remove the Ultimate/HD license bundle and replace it with a standard license.
Janne
Running PT 11 and 10 on the Same Machine robertgreenhouse Pro Tools 11 3 07-06-2014 02:31 PM
Running PT 10 and 11 On One Machine? Jaysun169 Pro Tools 11 6 07-03-2013 11:04 AM
Ultimate Drum Machine Samples RussUK Virtual Instruments 4 08-23-2009 11:04 AM
Running PT 6.0 and 5.1 on same machine jpd52 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-24-2003 03:33 AM
anybody running 001 on a non g3 machine? zeeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-25-2000 01:38 PM
