Old 04-25-2019, 11:58 AM
musicmixer04 musicmixer04 is offline
Default Omni Left heavy trs out when d sub out used
Hi
I have used Omni for a while now.
I use TRS 1+2 out for my main monitors.
Today I plugged in a dsub into the analog 1-8 output. Right away the sound on my monitors were quieter on the right side. Pulled out the d sub connector and it worked normal again.
Anyone have experience with the balance change on trs out when just plugging in a d sub to the analog output d sub connector. This seems very strange.
Any fix for this?
thanks
Old 04-25-2019, 02:25 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Omni Left heavy trs out when d sub out used
I'd take a voltmeter to check that dsub wiring. It sounds like a short-circuit to me
Janne
Old 04-25-2019, 04:06 PM
LDS LDS is offline
Possibly one of the channels in the Dsub is de-balancing itself, which will cause a 6dB drop in signal level if you are feeding balanced inputs.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 06-14-2019, 02:21 AM
Thanks for reply:)
spot on. I had put an unbalanced plug into the patchbay on one of the outputs by a mistake., and that was it.
So many clever people around these boards, Thanks so much for helping:)
Cheers
Routing? Car panned from right to left. Now a slap delay parallel from left to right? Sir Hannes macOS 2 06-10-2018 11:31 AM
Omni can't pan left or right headphone out willl3 Pro Tools HDX & HD Native Systems (Win) 5 06-26-2013 02:43 AM
Sound is left heavy Gabriel_S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-24-2011 04:56 PM
HEAVY.. HEAVY 001 song!! GORILLA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-16-2002 07:12 AM
Reverb plugs coming back "LEFT HEAVY" darla Pro Tools TDM Systems (Mac) 3 09-03-2001 02:32 PM
