digidesigns hardware is in use problem!
Hello all!!!
I have some problems with my digi002R system The computer is a 3.0 Ghz p4, 1Gb ram, internal firewire on the mobo. The mobo is a QDI P4I865PEA-6AFL. To the problem!!! The problem is that sometimes when i start ProTools a message comes up and it says Digidesigns hardware is in use by another application.(-1133) HELP!!!!! |
Re: digidesigns hardware is in use problem!
Sounds like you have the ASIO or WaveDriver installed and another app (or the system) is running which is holding onto the hardware.
Rail
thanks for answering!
I dont know if i have the asio or another wavedriver installed but i dont think so I dont run any other applications than ProTools on this machine... The PC is brand new and the only thing thats installed is ProTools.. I dont have the SP2 installed either Jakeelee |
Confirmed...the asio or wavedriver is NOT installed
problem still exists!!!
please help! |
Which chipset does your onboard FireWire card use? A wild guess would be that an Adaptec 4300 FireWire card would more than likely fix the problem.
Rail
Its a via chipset
Definately replace it with a TI chipset FireWire card. Check the compatibility link below for compatible FireWire cards.
Rail
i will do that....
Thankz!!! |
tried to update the via chipset drivers first--.....seems to work so far....
of its not....i will buy an adaptec 4300 today |
digidesigns AS plugins | joeydego | Pro Tools M-Powered (Mac) | 4 | 11-11-2008 11:32 PM |
Digidesigns Hardware issues,post them here... | gdx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-06-2008 11:40 AM |
Digidesigns support for Windows | Holadrio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-17-2004 12:15 AM |
My IRQ says I have 2 Digidesigns in 10 and 11. | TriAxis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-09-2001 11:19 AM |
What are Digidesigns plans for Surround Plug-Ins? | Ah D O | General Discussion | 1 | 04-15-1999 01:39 PM |
