Old 11-30-2021, 03:23 AM
Default Re: Pro Tools won't record MIDI from Plugin
Originally Posted by Heggi View Post
Hi Dave!
Yes, it definitely seems like it should work...
I only set up both tracks (instrument and MIDI) to show that none are recording. With the Instrument track the screen capture is a bit sloppy I admit. Just as I started recording, the cursor reached the end of the marked area. I actually routed Trigger to both tracks independently. So it's the same with both types of track, unfortunately.
What bums me the most is that both tracks receive input signal. Still it isn't recorded.
Does anyone know about any sort of disc allocation settings for MIDI? Or do I need to give PT any special disc writing rights in macOS security settings? Audio recording seems fine though... I'm really out of ideas
You didn't answer my post - it doesn't appear that you hit record in the PT transport. You apparently only armed the tracks for record and that's it.
Jack
QAPLA!
Old 11-30-2021, 03:31 AM
Heggi Heggi is offline
Hi Jack!
My apologies, I totally missed that!
Yes, I am recording. You can see in the video that PT creates clips.
Old 11-30-2021, 08:12 AM
Marsdy Marsdy is offline
Hi Dave!
It does seem like a bug. Can you try a different plug-in that generates MIDI? What happens if you try to commit the MIDI or instrument track? Also, does the track with the DB33 record successfully? Taking Trigger out of the equation, I presume you can record successfully from a MIDI keyboard?
MIDI recordings/clips are saved to the PT session file so no separate disk allocation.
Dave Marsden
UK
Old 11-30-2021, 11:31 PM
Hi Dave!
Thank you for all the input!
So now it gets weird... Recording via Keyboard Input (I don't have a MIDI input device set up as I am currently between studio places) works perfectly well. Switching from Trigger to Drum Lever actually did record some MIDI events, but by far not all of them. Still I can see every event at the input meter and I can also hear every event from the organ.
Committing the track (you meant committing the MIDI/Instrument track with empy clips, right?) didn't make any difference.
Somewhere I read that changing the buffer size might help. Unfortunately also no difference.
I might add that since my reinstall PT shows me different buffer sizes and also the next window keyboard shortcut (CMD+[key next to left shift]) doesn't work in PT anymore. Something seems wrong here...
Old 12-01-2021, 04:18 AM
In a cursory look at the shortcut manual I can't find a shortcut for next window. Don't know about your computer keyboard but on a standard keyboard the key next to the left shift key is the letter 'z'. Command-Z is the shortcut for 'undo'.
Jack
QAPLA!
  #16
Old 12-01-2021, 05:21 AM
Hi Jack!
Thank you for your effort!
I don't quite know what to say without going too far OT or stating the obvious. I can't say very much about English layouts as I use German. The only thing I can say for sure is that on my keyboard this key exists and that the shortcut worked before. It does work in PT if I switch to English layout btw
  #17
Old 12-01-2021, 05:54 AM
Hi Jack!
If you switch to English layout that key becomes the letter 'Z'.
Jack
QAPLA!
  #18
Old 12-02-2021, 01:25 AM
Okay, so after trashing preferences and reinstalling PT didn't work either, I performed a complete re-reinstall of the entire system. Again...
Next window command now works again, so that's a win already!
I also managed to circle in on the issue. It seems it has something to do with buffer and/or latency compensation:
Melda Drum Leveler has a button to turn on or off delay compensation for MIDI extraction. If turned off, recording on a MIDI/Instrument tracks works perfectly well. Only issue being a displacement.
Trigger latency set to "live" also works as I know it, including the issue that at some point PT doesn't write a note off event which results in a note that lasts forever.
Changing latency or buffer settings in PT globally doesn't seem to make any difference.
I also remember that the last time I used this way of creating MIDI was on an older version of PT. So could someone maybe try to recreate the issue? It might be a real bug?
MIDI Record works but not Retrospective MIDI Record or MIDI Loop Record cantfindabed Pro Tools 2019 16 05-31-2020 02:22 PM
Record Midi from Yamaha prs 220 keyboard Pro Tools 9 blackbird99 macOS 3 09-19-2015 11:38 AM
Pro-Tools Won't Record MIDI terrafirma 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-05-2014 09:10 PM
pitch to midi pro tools plugin Jayoel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-06-2009 11:47 AM
Audio and Midi record EARLY in everything but Pro-tools!!! errorspending 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-14-2008 10:50 AM
