Old 08-18-2019, 10:40 AM
reichman's Avatar
reichman reichman is offline
Default 19.7.0.101 – issues
My surface order is:
Dock
S3
Control
And I did a complete uninstall (including user prefs) before running into this. Two frustrating bugs that I don't remember seeing in 19.5:
1.) S3 sends in flip mode write automation, but the faders often don't move to the right position. Or some do, and one doesn't. And then as soon as I attention that track on the Dock (which shows the right automation in Control), the S3 snaps into the right place.
2.) the old VCA-spill problem where the first member in the VCA group is left out still happens.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 08-19-2019, 09:12 AM
EddieJones's Avatar
Default Re: 19.7.0.101 – issues
Can you try putting the S3 first in the list
Old 08-20-2019, 07:32 AM
reichman's Avatar
With S3 on top, it's not completely clear if my issues are resolved. BUT, when it is on top as follows:
Avid S3
Dock
Control
I have a new issue, which is that in a layout when the Dock fader is set to attentioned track, it only controls the first track in the Layout. Doesn't follow the attention despite what the iPad screen says. Totally repeatable bug. Contact me if you need help recreating this.
Nathaniel Reichman
Old 08-20-2019, 05:32 PM
mattrixx mattrixx is offline
I just tested this as well Nathaniel and had the same issue.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 08-21-2019, 06:51 AM
reichman's Avatar
Thanks for confirming matrixx. Are you seeing the odd behavior of sends, too?
Old 08-21-2019, 04:56 PM
I have seen strange behaviour with the sends, but not consistently.
Matt McKenzie-Smith
mattrixx.net
Old 08-21-2019, 09:16 PM
EddieJones's Avatar
Which issue...the first post or 2nd. We can't reproduce the first post but can the second.
Old 08-21-2019, 09:21 PM
Sorry Eddie, I meant to say the first ...
(1. S3 sends in flip mode write automation, but the faders often don't move to the right position.)
Bu having said that, it's not always the case.. I just tested again on the job I am currently working on and it's fine.
Matt McKenzie-Smith
mattrixx.net
Old 08-28-2019, 04:23 PM
reichman's Avatar
Ok, some more info. I've been switching between sessions all day, and I have a session where the flip fader send on a track is not moving at all unless I attention it, and suddenly it starts moving. Having Dock or S3 on top doesn't make a difference. Closing the session and reopening the session cleared it up. Spooky.
And just to be clear, I spilled a VCA, then flipped, and wrote send automation to a track in the VCA that was clearly recorded in Pro Tools and sounded good. Unspilled, kept working, then went back to spill and flip and noticed that the fader never moves. And when it's not in flip, the little send bar on the screen doesn't fill either. But Pro Tools makes the right sound!
Nathaniel Reichman
Mbox Gain Issues and Protools Issues (Bounce to Disk and Knob/Pot adjustments) Lucky Bastard Getting Started 6 01-16-2014 03:29 PM
No sound - asio driver issues - NTFS issues mitchelljrickey Windows 0 06-21-2012 05:35 PM
ProTools 9.0.5, iLok issues, Digi 003R+ issues zachbot Pro Tools 9 6 10-12-2011 08:19 PM
8.0.4 Issues (Quick Punch & Mute/Solo issues) pauledwards 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2010 09:35 AM
Digital Noise Issues - Clock Source Issues? Gorbies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-07-2010 01:55 PM
