Old 02-17-2021, 03:57 PM
inti productions inti productions is offline
Default Mac Pro 2019 running ProTools Ultimate, won't go to sleep.
I have a Mac Pro 2019 running with Catalina. Also Protools Ultimate 2020.12.0 is installed. When I put the computer to sleep the screen goes off, however the computer won’t sleep, the fans keep on running 24/7
Mac support just told me "This appears to be related to Digidesign. They are suggesting uninstalling the software or working with the developer to figure out if there is a setting that can be changed.”
Anybody experiencing the same problem? Thanks!
Old 02-17-2021, 04:19 PM
Ben Jenssen's Avatar
Default Re: Mac Pro 2019 running ProTools Ultimate, won't go to sleep.
Welcome.
Is Pro Tools running?
What does Activity monitor tell you about cpu activity?
Are fans noise a problem? If not then you might consider just sleeping the monitors and not the mac, like many of us do. Sleep has been known to make troubles with PT.
Check out optimization and other recommendations here:
Help Us Help You
Old 02-17-2021, 04:20 PM
JFreak's Avatar
JFreak JFreak is offline
Hi, welcome to the community.
PT does not suppoirt sleeping. You need to either disconnect hardware or shut down computer.
Janne
Old 02-17-2021, 04:53 PM
Southsidemusic's Avatar
Yeah ALL sleep and power saving settings should NEVER be used with PT or any other DAW. Just don’t put the comp to sleep. Turn off the computer every time.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 02-17-2021, 09:27 PM
_JJ_ _JJ_ is offline
As suggested, save and quit ProTools before putting your machine asleep. And if you haven't already, maybe uninstall Link which is a system and net hog.
Old 02-18-2021, 04:57 AM
Never let a computer running PT to sleep.
Your support message makes no sense. Digidesign as an entity hasn't existed for ages. Working with which developer? Avid knows there's no setting to change to make sleep mode on a computer work.
Jack
QAPLA!
Old 02-28-2021, 12:00 PM
Default Re: Mac Pro 2019 running ProTools Ultimate-HDX Card, won't go to sleep.
Thanks to all for your reply. I'm new to this forum. I omitted important information about the problem on my first post. I posted this following update, but I can't find it anymore. So here it is again:
Since I installed my ProTools HDX card running PT Ultimate, my Mac Pro 2019 won't go to sleep. The screen goes to sleep, however, the computer fans keep on going.
After many tests, Apple Support suggested the HDX card may be the problem.
With ProTools support we created a partition with a new OS. I removed the card, put the computer to sleep and it worked, the computer went to sleep, no fans running.
My case has been escalated to the engineering department. They are trying to re create the problem. Haven't heard from them yet.
I should mention that I have been using this HDX card for many year in my old Mac Pro 2012 with no problems. Is the HDX defective?
Is anybody else having a similar issue?
Thanks!!!
Old 02-28-2021, 12:11 PM
JFreak's Avatar
Do I need to say this third time?
Janne
Old 02-28-2021, 12:19 PM
Thanks!!!
What part of PT does NOT support computer sleeping? They can't re-create the problem because it's NOT a problem. The HDX card is not defective.
Jack
QAPLA!
Old 02-28-2021, 01:14 PM
JFreak's Avatar
This is nothing new
https://avid.secure.force.com/pkb/ar...eadme/en328011
Janne
ProRes -Protools Ultimate 2019 prob on PC windows 10 edboy7 Pro Tools 2019 1 05-15-2020 02:54 PM
HDX Ultimate - 2019.10 7 2019.12 - video export issues anguswoodhead Post - Surround - Video 2 03-09-2020 02:33 AM
Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro rmccam Pro Tools 2019 11 02-28-2020 03:59 AM
Is Protools Ultimate 2019.10 working with S6L? JLC VENUE Live Sound Systems 1 11-08-2019 02:31 AM
2019.5 Ultimate on a Mac Pro 5,1 DenverAudioGuy Pro Tools 2019 44 05-28-2019 03:25 AM
