Old 02-17-2021, 07:17 AM
D'Animation D'Animation is offline
Default Mac mini 2018 - need a egpu?
I've jumped ship to a Mac mini (2018), running Mojave. I'd like to run 3 displays (34" ultra wide + 2 x 24" FHD). Is the internal GPU ok to run this or does an egpu take some strain/heat away from the machine? This is a postproduction studio, 5.1, HD Native + PT Ultmate
Thanks
Old 02-17-2021, 03:15 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Mac mini 2018 - need a egpu?
Try Setup first then decide.
1TB for GPU
HDMI +1-2TB depending on adaptor/hub (No GPU but adaptors$)
Old 02-17-2021, 03:18 PM
JFreak's Avatar
JFreak JFreak is offline
Mac Mini 2018 supports up to three displays, depending on resolution. One HDMI and two TB. I guess 4K is okay for three but 5K limits for two.
Janne
Old 02-18-2021, 02:37 AM
Farhoof's Avatar
Farhoof Farhoof is offline
It's not "needed", but people I work with are using this setup and told me the temperature dropped a lot when using an eGPU (95 C to 75 C), which also meant a lot less fan noise. Seems legit to me.
Old 02-18-2021, 03:06 AM
Yeah, was wondering if that was going to be the case. Haven't received the mini yet to try it but looking at used graphics cards in particular, the prices are pretty unreal due to the cryptocurrency mining craze
Old 02-18-2021, 03:09 AM
Yeah no 5k screens + have a TB3 dock with dual DP ports plus the HDMI on the machine. Waiting on the mini to be delivered so will see what happens
Old 02-19-2021, 08:17 AM
boomspot boomspot is offline
I’m running 34” and 24” 2k resolution monitors off my 2018 mini’s tb3 ports. I have an RX 580 in a Razer X eGPU that I haven’t been using because it’s flakey with the mini. Can’t run all monitors off the eGPU because the boot/login screen only appears if the monitor is connected to the mini. I’ve wasted too much time trying to get it working. Surprisingly the TB3 ports are more reliable driving monitors than the HDMI port. Occasionally the HDMI port won’t wake from sleep ... tb3 ports have been flawless with $80 HDMI to tb3 Apple adapters. Test without eGPU but if needed, one monitor to tb3 and 2 connected to eGPU should work fine.
D
Old 02-20-2021, 12:35 PM
D
Thanks Boomspot, really appreciate the info
Old 02-21-2021, 12:45 AM
Mike Thornton's Avatar
Mike Thornton Mike Thornton is offline
I am running two 4k screens very successfully off the internal GPU of my Mac mini 2018. I too found the HDMI output flaky and stopped using it. You will get better refresh rates using the TB3 and DisplayPort. In the end, the most reliable solution was a USB-C to twin DisplayPort adaptor from OWC. I went this way because I found not all adaptors were the same and the OWC one is approved for the Mac mini. Hope that helps.
Mike Thornton MIPS
Chairman Of Production Expert Ltd - home of Pro Tools Expert
Old 02-22-2021, 02:56 AM
Thanks Mike, setting up the machine this evening so I'll see how I get on with the HDMI. I have a TB3 dock with dual DP's and was thinking of just using the HDMI for one of the lesser used side screens. Fingers crossed anyways!
MBP 2015 with eGPU to Help GUI Lag tomaspal macOS 2 04-07-2020 12:24 PM
MAC Mini 2018 with eGPU 11miles Pro Tools 12 0 12-18-2019 12:45 AM
Mac Mini 2018 & PT... Boe Larsen Pro Tools 2019 14 11-18-2019 03:21 AM
Can I run 10 and 2018 on new Mac Mini? Adupr Pro Tools HDX & HD Native Systems (Mac) 10 03-03-2019 02:15 AM
HDX with 2018 Mac Mini A Chapman Pro Tools HDX & HD Native Systems (Mac) 5 01-17-2019 09:35 AM
