PPC G Drive - DAE Errors 9060 9031 9060 on playback
Hi guys,
Computer - Dual 2 GHz PowerPC running OS X version 10.5.8 Pro Tools 8.0.3 G- Drive Hi guys, I've been having trouble with G Drives on this PowerPC computer. Everytime I try to playback on here (recording was done on a Mac Pro) I immediately get DAE 9060; DAE 9031; DAE 9060. I read some threads that pointed to partitioning the drive with Apple Partition Map rather than GUID, but it makes no difference. Anyone run into this and can point me to a fix? |
Re: PPC G Drive - DAE Errors 9060 9031 9060 on playback
Whoops! Pro Tools 8.0.1-- typo!
did the G-Drive work OK on the Mac Pro?
we've has some problem with the G-Tech drives of late
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Yes it worked with no problem.. I've had 3 different G- drives through here in the last couple of months.. all work fine on the Mac Pro but not on the PPC
Okay so I transferred files to a Lacie drive and upon playback the same error messages popped up.
I trashed prefs, databases, volumes folders. The session was pretty big so I transferred half the audio onto an internal drive.. STILL getting these 9060, 9031, 9060 errors upon trying to playback. Sessions run fine on other external drives. Sessions run fine on internal drives. |
I'm new with Pro Tools SE also with a new Toshiba Laptop running Windows 7with plenty of power. After getting constant DAE errors when I tried laying down some tracks I finally ran a program compatibility check with my computer and it took the setup somehow back to a Windows XP setup and now everything works fine, no more DAE errors.
I'm not sure why it didn't like Windows 7 and I'm trying to find out if I need a patch of some kind or if I need to install and run the Service Pack one upgrade? In the meantime everything is working |
hi
these dae errors may come from illegal caractere in the audio file corrupted audio file apple journalization on HDD too fragmented wrong formating option between apple partition and GUID |
only underscore as "strange" caracters allowed or - on all drives and especially audio files
but no + check also if you have other connected drives that would be GUID. Disable journalization and spotlight indexing on all drives Might be a fragmented HHD so, do a complete defrag trash all digidesign database hope this will help |
9060, 9031 and low on memory errors. | tehguitarist | Pro Tools HDX & HD Native Systems (Mac) | 2 | 04-30-2011 02:00 AM |
DAE Errors 9060, 9031, and 9073 | AldenWitt | Pro Tools M-Powered (Win) | 0 | 02-10-2011 08:37 PM |
HELP! DAE -9060 -9031 errors(sandra) | ram130 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 35 | 06-20-2010 12:21 PM |
PT HD 8 RAID DAE 9060 and 9031 errors | rogmidd | Pro Tools TDM Systems (Mac) | 8 | 04-28-2010 02:57 PM |
-9060 & -9031 errors. | duffy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-23-2010 01:10 PM |
