video engine failed to initialize...
...I've noticed this message during the start-up sequence since the 7.4.2 upgrade. Thought nothing of it, b/c just before this message, I get the following messages: "launching video engine" then "no video hardware connected". Thought this some new thing with 7.4.2 that I would not worry about until I connected a camera? But now when I try to open an .omf I get a message that "some files could not be imported because the avid engine is not installed". Are these two msgs connected? Seems to make since if the video engine did not initialize that the avid engine was not installed...
Also, the only way I can even try to import omfs is by using the "import video" option. I don't recall having to do that before... Seem to recall that I could import under "import audio" tab, but clicking on an .omf in that instance gives me a "file unreadable by pro tools" message. Only reference I could find in the answerbase to these msgs was referring to an XP machine and old Avid drivers. Am I missing something here? Any help would be really appreciated, as I am starting a project today, and I would rather have the data omfs provide, rather than trying to import the audio from a QT movie! Many thanks in advance, Nathan
Studio: Mac Mini 2.6 GHz i7 16GB RAM PT 2019 and 10.14 UA Apollo Quad Outboard: 2 x Summit Audio 2BA-221>TLA 50>EQF-100 2 x dbx 165a 4 x Shadow Hills GAMAhttp://humpbackmedia.net[/SIZE] |
Re: video engine failed to initialize...
Did you install the video engine without having Mojo?
try uninstall, then install without the .Avid Video engine.option
http://felixrost.de |
That's the thing, I don't have Avid's Mojo... Or any other sort of hardware interface... which is why I at first thought the msgs weren't a problem. Maybe they aren't, and there's something else going on, but I can't figure it. So you're thinking uninstall PT and uncheck the option? I was hoping to install it so that when I can get an interface, I wouldn't have to do the process over again...
regarding:"some files could not be imported because the avid engine is not installed"
is there some video/referenced MXF data contained in the OMF? that could be the culprit
Well, thanks for the replies , Felix & DJ, but no dice . I did a clean uninstall and re-install without the video engine, and no dice. Any other thoughts anyone? This vexeth sorely!
Nathan
Oh, and Felix, as to the MXF info... I've tried importing a known good .omf file to aqccount for that possibility. No good either...
Remove the Video Engine folder if it is in the following location:
Applications/Digidesign/Pro Tools/Video Engine And also the Video Engine folder from here: Library/Application Support/Digidesign/Video Engine You don't have to delete them entirely, but you do need to move them to a different location.
Administrator Avid Pro Audio Community |
Thanks for the input digi, but this has not helped anything. Still the same problem - upon an attempt to import, I get "some files could not be imported because the avid engine is not installed"...
Video Engine Failed to Initialize in PTHD 7.3.1 | sheinke | Pro Tools TDM Systems (Mac) | 2 | 07-27-2009 04:58 PM |
7.4 video engine failed to initialize | greenwood | Pro Tools TDM Systems (Win) | 2 | 01-18-2008 12:40 AM |
Video engine failed to initialize on HD 7.3.1 | AlexanderSim | Pro Tools TDM Systems (Win) | 3 | 06-17-2007 10:22 PM |
Video Engine Failed to Initialize | tom.joyce | Post - Surround - Video | 2 | 12-19-2006 09:40 AM |
Video Engine Failed to Initialize | JimLeb | Post - Surround - Video | 5 | 04-28-2006 02:58 PM |
