preamp routing
If I am using an outboard preamp, should I take advantage of the XLRS on DIGI inputs 1 and 2 or would it be best to bypass the digi preamp on these inputs and choose another set of inputs?
BTW, I have the Behringer Tube UltraGain. Any comments on this unit? |
Re: preamp routing
Crushed, it would be best to use one of the TRS inputs on the rear of the 001. You normally would not want to double the pre-amp
on a signal, unless that is the sound you are looking for. If your pre does not have trs outs, you can purchase a xlr-to-trs cable. As far as the unit is concerned, i have a behringer ultragain pro, it has one 12AX7 russian tube, its extremely transparent. phase reverse, EQ, phantom power...i only paid $150 for it, 2 channels...its a different sound, not the 1st pre i reach for.. I think your model is a higher end one? peace sdf |
Using outboard Preamp/Bypassing Mbox2 Preamp | KennyC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-10-2007 12:00 PM |
002R Preamp and Outboard preamp | jimbojimbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-21-2007 06:49 AM |
Studio Projects VTB1 preamp vs ART TPS-II preamp?? | ESR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-28-2004 09:23 PM |
I'm torn.. Digi001 with better preamp or Digi002 with cheaper preamp/future upgrade | Siberian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-05-2003 11:22 PM |
Routing a Mono PreAmp. | OgnKog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-27-2001 01:37 PM |
