Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S3
  #21
Old 01-31-2015, 03:42 PM
Kristo Kotkas's Avatar
Kristo Kotkas Kristo Kotkas is offline
Default Re: S3 Fader stop working
"Stuck fader" issue should not be new to Avid, some of us from the live sound side have reported these issues on S3's from summer 2014.
So far the solution has been fader replacement, but since the faders in the unit are quite typical ALPS'es successfully used in number of other consoles it's likely a combination of slightly lower quality faders sometimes triggering a issue in fader firmware resulting surface dropping these faders as non-functional.
So for now I would keep an eye on if it's certain faders you see the issue happening to on your surfaces and then ask for replacement faders under warranty, that should inspire Avid to come with a software fix quicker
VENUE FAQ & download links, useful
AVID VENUE ILok driver download
VENUE Plugin DSP usage
My AVID:
  • Room A > HD4Accel PCI-CustoMac / 192D / PTHD10 / 2 x Artist Mix / Artist Control
  • Room B > HD3Accel PCI-CustoMac / 192D / PTHD10 / 2 x Artist Mix
  • Big Live > VENUE Profile 48/24 + 2nd Snake card, IOx, FWx, HDx, PQ Rack, 8 x PQ Controllers
  • Small Live > S3L-32 + Mac Mini - two systems - combined one 64/32 FOH / Mon setup
  • On stage > Pro Tools on laptop with variety of M-Audio boxes
  #22
Old 02-01-2015, 02:50 AM
domilik domilik is offline
Originally Posted by Norrie View Post
Never had that just that the fader would go to sleep until it had been power cycled.
What happens if you put it if Vegas mode and test the faders ?
I did not even know, that there is a vegas mode for the S3. Do you know how to initialize it? Could not find anything about this in manual or google.
As you see, the two faders (#12/16) nearly always get stuck when hitting the 12dB-max. The same two faders are getting lost completely from time to time until reboot.
  #23
Old 02-01-2015, 02:55 AM
Norrie's Avatar
Norrie Norrie is offline
http://avid.force.com/pkb/articles/e...lity-Test-Mode
From here you can access vegas mode and other fader / light tests including changing led brightness back light colours etc etc
should help with the testing :)
I don't suffer from insanity -- I enjoy every minute of it !
Avid S3
Artist Transport
Pro Tools HD 12
UAD Apollo 8P
Audient ASP 880
Mac Pro TrashCan
3.5 GHz 6-Core Intel Xeon E5, 32GB ram
Adams A77x
UAD Quad Thunderbolt Satellite
  #24
Old 02-01-2015, 03:59 AM
Thank you, I've run the vegas, same fader-problems there: Stucking of #16 at 12bB (but much less compared to my test-runnings coming from DAW), then it also got lost completely after some time...
  #25
Old 02-01-2015, 04:09 AM
Norrie's Avatar
There are also other fader test modes you may want to try. Sorry I'm not in front of mine right now.
Avid S3
Artist Transport
Pro Tools HD 12
UAD Apollo 8P
Audient ASP 880
Mac Pro TrashCan
Adams A77x
  #26
Old 02-09-2015, 07:05 AM
willco willco is offline
I have the same problem as most people here - fader just goes to sleep after an hour or a few... it's the same ones repeatedly.
I am on my 2nd replacement!!! That's S3 no.3 and it's got the same problem <facepalm>
It's fader number 5 on this one so far...
  #27
Old 02-23-2015, 11:50 PM
Mikers Mikers is offline
Couple weeks ago i got my S3 with replaced fader from polish service. Everything was fine.
Yesterday i upgraded firmware via eucontrol and 2 faders started stacking.
Something is wrong with firmware 1.1.1. I did downgrade to 1.1.0 and faders works correct.
It's very annoying….
http://www.120db.pl
PT 11.3, S3L-X 32ch, Mac Mini i7 - Yosemite
  #28
Old 02-24-2015, 05:46 PM
Norrie's Avatar
I see you are also on yosemite though and that's not support
Avid S3
Artist Transport
Pro Tools HD 12
UAD Apollo 8P
Audient ASP 880
Mac Pro TrashCan
Adams A77x
  #29
Old 02-27-2015, 09:44 AM
Oh dear, I am on controller number 4.
Fader 8 drops out on this one...
All credit to my supplier KMR for helping out, they really are doing everything they can...
Avid can you comment on what's going on?
I appreciate the advice re: vegas mode etc, but you have to power cycle the controller to get into that mode and re-starting it jogs the fader back to life so it's not a useful test I am afraid.
  #30
Old 03-02-2015, 05:51 PM
Klangfarben Klangfarben is offline
How did you downgrade to 1.1.0?
Outputs Stop Working 11.2.1 Nathan W. Pro Tools HDX & HD Native Systems (Mac) 0 10-23-2014 02:44 PM
Stop fader banks from following track focus? trustyjim ProControl, Control|24, Command|8 14 02-02-2013 05:13 PM
PT 7.4 Mac OS X Menus Stop Working swlego Pro Tools TDM Systems (Mac) 43 01-20-2009 06:20 PM
C24 fader stop reacting aux ICON & C|24 1 02-14-2008 03:42 PM
help! plugins stop working! nattyl001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-08-2005 11:07 AM
