Old 09-12-2012, 05:22 PM
Touchwood Studios Touchwood Studios is offline
Default Realtime Sample Rate Convert
Does this work on AES Transmit data or Only Receive Data?
Old 09-12-2012, 08:18 PM
nst7 nst7 is offline
Default Re: Realtime Sample Rate Convert
Are you talking about the Omni? If so, it looks like it only works when receiving a signal, not transmitting.
Old 09-22-2012, 03:31 PM
192 i/o
I want to use a outboard Digital Reverb that is AES only @ 48K/44.1K
Old 09-22-2012, 06:12 PM
LukeHoward LukeHoward is offline
Originally Posted by Touchwood Studios View Post
192 i/o
Not a Quantec Yardstick is it?
You'll need a sample rate converter on the send (look for the z-link96 which comes up from time to time on eBay). You can just enable SRC on the return (the input on the 192 or HD I/O).
https://lukehoward.com/
Old 09-23-2012, 12:11 AM
The receive SRC works - but it does not SRC on Transmit to the reverb.
Old 10-06-2012, 12:12 AM
roberts roberts is offline
Not working with a AES source @ 44.1 into a 96K session - looks like Real Time Sample Rate convert is broken in 10.3
Old 10-06-2012, 10:40 AM
cmaynes's Avatar
cmaynes cmaynes is offline
if you are sending a 96k digital signal FROM ProTools to a 44.1k reverb input- it will not work- unless the reverb has an input SRC, which probably wouldnt function at 96k to begin with.
if you want to test wether the SRC on PT's input is broken you should feed the reverb from an analog input- and take its digital output to the AES input on the interface with SRC enabled. As was mentioned, there is no output SRC on any Avid interfaces (at least that I know of).
charles maynes
sound design and recording for film and media
818 618 0580
Member IATSE Local 700, MPSE, ATAS, NRA & USMCHC.
192 Sample Rate Convert Touchwood Studios Pro Tools HDX & HD Native Systems (Mac) 1 08-21-2012 03:51 PM
192 I/O realtime sample rate conversion? Simon R. Tips & Tricks 21 12-15-2009 09:24 PM
Sample rate convert when bouncing.. ghost22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-04-2007 12:10 PM
convert sample rate stamp? whosmatt Pro Tools TDM Systems (Mac) 2 06-05-2006 06:23 PM
BTD only way to convert to 44.1M sample rate? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-19-2001 03:26 PM
