Old 12-10-2019, 08:52 AM
creativecontrol's Avatar
Default Re: 19.12?
I’m not seeing any of these issues with the latest versions of all 3 DMG EQ plug-ins and 19.12. It’s more likely it has to do with the plug-ins which proceed or follow these EQ’s on your channels.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-11-2019, 03:17 AM
rcutz rcutz is offline
Default Re: 19.12?
From A to D :
Fabfilter desser
Equality
Fabfilter pro Mb
Fabfilter Pro Q3
Mcdsp Sa2
Cedar dns one
Can you test there, cause I already reset to 19.9 and PT 19.12?
Ricardo Cutz
Re-recording mixer/sound editor supervisor.
Http://106db.com.br
Old 12-11-2019, 09:40 AM
Default Re: 19.12?
No issues here.
The picture you posted is of the (correct) expanded EQ appset for McDSP SA-2. It appears that you inadvertently cycled through and landed on SA-2 presuming it was in fact DMG Equality.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-12-2019, 06:15 AM
Default Re: 19.12?
Originally Posted by creativecontrol View Post
No issues here.
ohh.. I see. but...
I have set my cycling to start at the slot B (equality).
So, by the info you gave me, the SA2 is expanding on the first press on the EQ button - shouldn't it be the Equality? And even after several presses, the Equality did not shows up - no cycling occurs.
So my complaining was wrong, but now, knowing that you bring up, I understand that when I press the EQ button the first EQ is to come up, right? If that assumption was right, is there some issue here?
Is it possible to set S6/Pro Tools to not cycle?
best
Ricardo
Ricardo Cutz
Http://106db.com.br
Old 12-12-2019, 12:52 PM
Default Re: 19.12?
No. I’m note sure why it would be necessary to disable cycling? It requires a pretty deliberate multi-push to get it into a cycle mode.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
