Reset IO settings?
Hi folks,
I've jut notice that when I open AutoTune in Audio Suite I can't audition before rendering. I get a message re IO settings that there isn't a path set up to audition (or words to that effect) I was trying to help a friend with his I/O settings over the phone and i think I must've changed something? Prior to this I've never changed anything in I/O. How do I reset/restore to factory defaults? Idiots guide needed! Thanks.
Pro Tools HD Native Thunderbolt, HD IO 8X8X8,ProTools HD 10.3.0 External 1 TB Storage, Apple Mac Mini Processor 2.6 GHz Intel Core i7 Software OS X 10.8.2 Memory 16 GB 1600 MHz DDR3 |
Re: Reset IO settings?
You can go to setup I/O settings and under the output tab you can select the audition path! Just set this to left and right output etc, Then You will hear audiosuite audition. You could reset the I/o settings to default from the I/o settings page. Chris
My TC-DAT needs to be reset??? | Halstein | Post - Surround - Video | 8 | 10-24-2009 04:27 AM |
Pro tools click settings (1/8 notes or 16th note settings )? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-19-2008 09:59 PM |
Cannot save plug-in settings to Root Settings folder | SimonORorke | Pro Tools M-Powered (Win) | 1 | 01-18-2008 08:38 PM |
003 reset | albee1952 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-14-2007 01:29 PM |
Amplitude Settings reset... | qbert1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-04-2004 07:29 PM |
