Old 11-15-2014, 11:16 PM
larsongs larsongs is offline
Default How to change entire Songs Tempo
I've recorded a Project. After listening several times we all agree the Tempo is to slow & we want to speed it up without altering the Key of the Song & the Pitch of the Vocals.
I've been on You Tube & Reference Guide trying figure out how to change Tempo of entire Songs using Elastic Audio.
The You Tubes don't look like Pro tools 10 Edit Screen & I can't figure put how they are selecting all Tracks, changing all Tracks to Ticks, setting to Elastic Audio & selecting the right mode. Polyphonic is what I think it's supposed to be.
I can't seem to find it in the Reference Guide either. All kinds of stuff about Elastic Audio but I'm not seeing how to change Tempos of whole Songs?
I did manage to change Tempo but not all the Tracks were syncing. Some were ahead or behind?
Appreciate your wisdom all!
Thanks,
Lars
Old 11-16-2014, 02:33 AM
Raoul23 Raoul23 is offline
Default Re: How to change entire Songs Tempo
Hi Lars
IIRC all tracks need to be in tick mode (elastic audio) and the increase the tempo and all tracks should move with the tempo.
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 11-16-2014, 05:15 AM
Drew Mazurek's Avatar
Turn on Elastic Audio for each track by choosing the algorithm that best suits the tracks content. Then make sure all tracks are Tick based not Sample based. Option clicking will help here. Once analyzed, all tracks will change as the tempo is changed.
www.drewmazurek.com
Old 11-16-2014, 07:26 AM
All Tracks don't have to be Polyphonic, Monphonic or whichever. They can be different as long as as all are in Tick mode?
Not sure I'm selecting all Tracks correctly? I Hold Command then Click a Track & they all light up. Is that right?
Thanks,
Lars
Old 11-16-2014, 08:16 AM
Thanks,
Lars
Correct. The algo is based on track content (drums need rhythmic etc) and Tick Based means it'll follow the conductor track.
No, Option click Tick Based for do to all. Algos you'll want to do more carefully, possibly on a track by track basis.
www.drewmazurek.com
Old 11-16-2014, 11:09 AM
I will give it a try!
Thanks,
Lars
Old 11-17-2014, 06:30 AM
stickboymusic stickboymusic is offline
Also I suppose you could just bounce the track down..... import into pro tools...and use audiosuite/pitch shift/time shift
You would probably get better results with the method above but it may help you decide on the correct tempo quickly
Old 11-17-2014, 09:19 AM
I did it! What a cool feature!
But, I had manually change each Track to Tick. Isn't there a way to select all & change all the Tracks to Tick at the same time?
Thanks,
Lars
Old 11-17-2014, 06:06 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Not at my system to test, but I think it's what Drew is telling you, option + click 'Ticks' = changing all (guessing as long as all tracks are selected)
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 11-17-2014, 06:17 PM
Thought I tried that? I'll try it again. I really dig this feature!
Thanks,
Lars
change clip volume for a entire group Talisker Pro Tools 10 2 03-13-2013 08:33 AM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Easiest way to raise tempo of entire project... products7074740 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-31-2009 03:43 PM
Pushing back the entire songs start time. d00m1001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-23-2009 06:30 AM
Ramping a Tempo Change (interpolation or discrete tempo points) edgarbc1 Tips & Tricks 3 02-18-2009 12:55 PM
