Old 11-24-2020, 10:32 PM
johnbarnesiii johnbarnesiii is offline
Default MacBook Pro & PT 12.5 - Upgrade & Compatibility
Hi guys, I’ve been using PT 12.5 on an older (late 2011) MacBook Pro to record with. After many years of great use, the logic board on the Mac went bust, so I’m needing to upgrade laptop...
My question is regarding compatibility. My system was setup and working within PT 12.5 on an older Mac OS (El Capitan 10.11.6). I was also using certain virtual instruments and plugins, namely Arturia V Collection, Kontakt, Sampletank, and the Waves bundle...
So I’m wondering, in searching for a different Mac laptop, which specs do I need to ensure that I can still run my PT 12.5 perpetual license, as well as my virtual instruments & plugins? Do I need the newer laptop to remain on the same OS El Capitan 10.11.6 as before, or will certain things stop working if I upgrade past that version of Mac OS? I’m wanting to buy a MacBook Pro that’s a little newer than the late 2011, but not so new that my old PT files & VST’s/plugins won’t work.
Trying to make a smooth transition as possible here. Which specs on a MacBook Pro would you recommend in terms of year & OS? Any tips much appreciated!
Old 11-24-2020, 11:04 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: MacBook Pro & PT 12.5 - Upgrade & Compatibility
New laptop will not be compatible with old OS
Janne
Old 11-25-2020, 03:00 AM
Thanks. I understand the new 2020 laptops won’t be compatible, but I’m wondering about a used one that’s maybe a couple years older than my 2011 and potentially being capable of having El Capitan on it? Maybe a 2013? Or 2012 even. Just wondering how far I can push it before being incompatible?
Old 11-25-2020, 07:03 AM
JFreak's Avatar
When a new hardware comes out, it is compatible with the OS it comes with, and later. Earlier are not going to work because there are no drivers for new hardware
Janne
Old 11-25-2020, 11:54 AM
I see. So you mean I’d have to find a used laptop with the exact specs (late 2011 MacBook Pro, with exact version of El Capitan 10.11.6) in order for it to continue to work with my PT 12.5, right?
Old 11-25-2020, 12:48 PM
JFreak's Avatar
Yes. Would be more sensible to buy newer hardware and update PT
Janne
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade benosullivan Pro Tools 9 2 11-17-2010 11:05 AM
MacBook compatibility thatwasfantastic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-22-2008 08:47 AM
MacBook Pro 15.4'' Compatibility DFG1984 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-11-2008 07:55 AM
New MacBook Compatibility JayJaay927 Pro Tools M-Powered (Mac) 7 12-23-2006 07:43 AM
New MacBook Compatibility Andrew814 Pro Tools TDM Systems (Mac) 0 12-01-2006 12:38 PM
