Old 09-29-2013, 10:35 PM
Fritz Fritz is offline
Default what to set User Offset for HW insert?
MBA4,2, UA Apollo 7.1,
Compex Limiter on HW insert for mix purposes only, as parallel processing to the drums.
In other words, one stereo aux with a plug that feeds the mix buss and one stereo aux with HW insert that feeds the mix buss.
What should the User Offset be or how to calculate it?
"Do not fear mistakes. There are none."
Miles Davis
Old 09-29-2013, 10:58 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: what to set User Offset for HW insert?
Hi, just taking a stab at this as I've never actually done it, but couldn't you simply record a signal that's been sent through your hardware, then compare the original signal to the re-recorded one on the timeline and calculate the offset?
Chris
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS Catalina 10.15.7
Pro Tools HD 2020.12.0
Old 09-29-2013, 11:14 PM
Craig F Craig F is offline
That's what I would do.
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 09-30-2013, 07:50 AM
hey, are you in my head?
As I nodded off last night I realized this method.
Thanks
Miles Davis
Is the User Offset (ADC) really working?? SD2 Pro Tools 9 5 05-24-2011 08:45 AM
Delay Compensation, User offset negative HiLoc Pro Tools TDM Systems (Mac) 4 04-03-2010 02:18 AM
User offset delay compensation field functionality Shut Eyes Pro Tools TDM Systems (Mac) 0 06-15-2008 06:00 AM
Negative "User offset" ADC numbers possible? Tim R. Pro Tools TDM Systems (Mac) 1 06-19-2007 04:14 PM
How to insert time / insert measures, without upsetting tempo map and markers imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-25-2003 06:45 PM
