10.5.2 compatibility
Hi!
I have a question to Digi´s following statement... Quote:
...even the new Xpand update for 7.4.1 works now with the normal not funky-yellow GUI on my setup! just curious btw hello Mac community, I´m new to the Mac forum, switched from PC/LE to Mac/MP Cheers P.S. my signature will be edited soon
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: 10.5.2 compatibility
hello???
Works with 10.5.2 for me. I had to uninstall and reinstall 7.4cs2 to be able to write to my volumes, but once I had done that, everything was fine.
Mac Pro 8-core 2.4 GHz, 10 GB RAM, Mac OS 10.7.1, PTMP 8.0.5, M-Audio Firewire 410 (driver version 1.10.3) |
So... 10.5.x has never worked for me as Digi indicates it wouldn't. I'm a bit surprised with what has happened since the 10.5.2 upgrade though... Digi even says not to upgrade 7.4.1 HD to 10.5.2 yet... Steve |
Compatibility - Pre-USB w/ 10.5.1 drivers on OS 10.5.2
I'll post this here and see if anybody sees it....
I have just gone from a MacMini with PTMPv7.4 (don't ask what build/version) running fine on 10.4 to a MacPro with Leopard and have already updated to 10.5.2, never had a chance to get 10.5.1. My interface is a Mobile Pre-USB. Besides using the Pre-USB for audio input, I've also been using it for system audio output (iTunes, QuickTime, etc.). I did a "Migration Assistant" drill when setting up the MacPro, which brought over ProTools, which appeared to be running fine in this environment despite not being qualified yet for 10.5.2. However, it appears that the Pre-USB may have been causing some problems with the OS, which manifest as problems for the computer going into or coming out of sleep mode. This happened even when ProTools had not been running -- because I was using the PreUSB for system audio out. The Mac Genius I spent an hour with today suspects that the "sleep" problems stem from the Pre-USB or its drivers (or both combined) and he advised against even bothering with the 10.5.1 driver update that is available from Digi. I imagine that the driver that came over with the "Migration Assistant" is of course a 10.4.x driver, since that's what PT was running on the Mini. So it makes sense that there would be a conflict with any version of 10.5. So, the question is: how compatible is the 10.5.1 driver for the Pre-USB with the 10.5.2 OS? Anybody have any idea? I'm reasonably certain that it's going to be more compatible than the 10.4.x driver, but... is it compatible enough to not cause the problems I've had with "sleep" mode? And.... how long after 10.5.1 came out did it take Digi to get around to qualifying it? By which I mean.... how much longer for the 10.5.2 version? --PS
"The difficult we do right away, the impossible takes slightly longer." -- Philo T. Farnsworth |
File this under "For What It's Worth" ...
I'm running MP 7.4cs2 on a MacBook Pro (Santa Rosa) with an M-Audio 1814. I recently upgraded from Tiger to 10.5.2 without a single issue so far. I haven't had to reinstall anything, run the pre-binding script or upgrade to the M-Audio beta drivers. The only thing I had to do was upgrade my iLok drivers. Here's how my upgrade process went. I originally had a single partition with Tiger on it. Using iPartition, I split that partition in half (I had the free space to do that) and then used SuperDuper to backup the Tiger partition to the new partition. I like SuperDuper for my backup software because it makes an identical copy AND it can create a bootable partition from your backup. I then had to two identical, bootable Tiger partitions (I wasn't ready to bail on Tiger until I was sure that the Leopard upgrade wasn't going to be a problem for Pro Tools). I set the backup partition as my startup drive, rebooted to it, repaired the disk permissions and then installed Leopard using the upgrade option on the Leopard installation DVD. Once it was done, I had a Tiger partition and a Leopard partition - identical except for the OS. I then ran the Software Update option of Leopard a few times until it finished updating everything and there was nothing more to get. The first time I ran Pro Tools under 10.5.2 I got a message that the iLok drivers needed to be updated and it gave me a link to the Pace site where that got resolved in a couple of minutes. Once done, I relaunched PT and it ran the first time (and every time so far) without issues. Granted, I'm not using a lot of plug-ins beyond what came with PT but the few I am using seem to be working just fine. I still have my Tiger partition in case some PT problem rears it's head but so far so good. FWIW. |
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade | benosullivan | Pro Tools 9 | 2 | 11-17-2010 11:05 AM |
V9 Compatibility | GTBannah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-16-2010 04:51 PM |
Mac OSX Compatibility | Keniko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-24-2007 09:33 AM |
UAD-1 and PT7 Compatibility | M15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-08-2005 11:19 PM |
PCI-X Compatibility | kcurry | Pro Tools TDM Systems (Mac) | 6 | 07-14-2003 05:45 AM |
