Vocal Tracking
Hey guys,
I need some pointers about tracking vocals for a project. Here are the specs: Everything except the vocals is complete. Thanks to you all, I've become somewhat swift and efficient, and the audio, MIDI and drums sound awesome!! Now for these vocals... The song is just shy of 3 minutes, and I'm layering vocals one over another. I have about 8 tracks (vox) and it's getting somewhat frustrating. With so many tracks, it gets complicated fast. There are certain parts, like the chorus, I want to double up, and have backup vocals panned hard left hard right. I'm trying to stay organized with all of this to avoid the sloppiness and forgetting which part is where. There must be an easier way than how I'm approaching this... because it still becomes unorganized! Any help would be awesome, Thanks!! -Justin
Mac Mini OS X 10.8.5 2.3 GHz Intel Core i7 16 GB 1600 MHz DDR3 Pro Tools 10, 003 Rack, NI Maschine www.youtube.com/firsty33 |
Re: Vocal Tracking
Not sure exactly where your problem lies by your description, but a couple of general pointers that can help in staying on top of things are naming the tracks before doing a take. This way the audio files and regions are automatically named. Also using playlists for alternate takes of the same track will help keep the session manageable as far as track count goes. If your initial playlist for a track is "Lead Vocal", add ".01" to the end of the name then when you create a new playlist it'll automatically name it "Lead Vocal.02" and so on.
Although keeping up with the vocalist and keeping the session moving is of utmost importance, if you're going to be comping it's good to do this as you go. You'll have the talent there to give input, the takes will be fresh in your mind and you'll have a much clearer idea of what you do or don't have. |
Re: Vocal Tracking
8 tracks is nothing! LOL try working with 30 to 40!!!
Here's some things I do... setup mono or stereo aux tracks for your different groups of vocal tracks. For example, I have one mono aux for lead vocals. Any lead vocal tracks I create (Verse1 Vox, PreChorus 1Vox, Chorus 1Vox, etc) all get bussed to that Aux. All the effects I put on the lead, I put on the Aux, not the channel itself. The only things I put on the channels themselves is corrective effects. For example if we used a second verse from a take a couple weeks ago and it sounds different, I might put EQ on the track to make it more closely match the other tracks. Same thing with doubles and backgrounds. For those I usually create stereo Auxes so I can pan the source tracks into the Stereo Aux. So I'll have this... LeadVoxDbl 1 LeadVoxDbl 2 BGVox 1 BGVox 2 BGVox 3 etc... For more complex songs I use numbers and letters. for example, if I am going to triple track EACH harmony part in a 5 part BG Vox harmony... then I'll have BGVox 1A BGVox 1B BGVox 1C BGVox 2A BGVox 2B BGVox 2C etc... You can group the tracks together. And if you want you can create a separate stereo aux for each (BGVox 1 Aux, BG Vox 2 Aux) Color coding is also your friend.Color code the different sets of tracks so you can quickly see which is which. A typical track list for vocals for me on a big mix will look something like this... Lead Vox SubMix(Aux) Lead Vox V1 Lead Vox P1 Lead Vox C1 Lead Vox V2 Lead Vox P2 Lead Vox C2 Lead Vox Bridge Lead Vox C3 Lead Vox Outro Adlib(Or Riff) Vox Submix (Aux) Adlib 1 Adlib 2 Adlib 3 VoxDbl Submix (Aux) VoxDbl 1 (Or Center) VoxDbl 2 (Or Left) VoxDbl 3 (Or Right) BG Vox 1 Submix (Aux) BGVox 1A [1st harmony part] BGVox 1B [1st harmony part] BGVox 1C [1st harmony part] BGVox 1D [1st harmony part] BG Vox 2 Submix (Aux) BGVox 2A [2nd harmony part] BGVox 2B [2nd harmony part] BGVox 2C [2nd harmony part] BGVox 2D [2nd harmony part] BG Vox 3 Submix (Aux) BGVox 3A [3rd harmony part] BGVox 3B [3rd harmony part] BGVox 3C [3rd harmony part] BGVox 3D [3rd harmony part] BG Vox 4 Submix (Aux) BGVox 4A [4th harmony part] BGVox 4B [4th harmony part] BGVox 4C [4th harmony part] BGVox 4D [4th harmony part] Now... when you start mixing... hide (but leave active) all the audio tracks and just leave the Aux tracks. Now all your vocals are on 7 Aux tracks that you can automate and blend as needed... if you need to tweak the blend within any group, show it, tweak/automate the audio tracks, hide and go back to mixing. On HD systems I use VCA tracks as well for a similar purpose, but you can't put plugins on VCAs. So for things like the lead vocal, I'll usually use a VCA and an Aux. But for the BG Vox, I'll use 4 VCAs (one for each group) but have all of them sent to one Aux instead of 4 auxes. And this also works for guitars as well. I normally use 3 or 4 mics on each guitar cabinet. And I'll usually end up doing at least 4 or 5 passes of guitar, which turns into 20 audio tracks for guitar. I use the GTR 1A, GTR 1B, etc system so I can see which set of tracks is which... and I usually will bus them to Aux channels or use VCAs to manage controling their overall levels. And... obviously, this also works for recording live string sections, brass sections, etc... Frequently when recording orchestral music we have the section double and/or triple themselves and then also do "divisi" parts. Each pass will have between 6 and 16 tracks (depending on how I am mic'ing the section). Using the 1A, 1B, 2A, naming system on the tracks tells me instantly if this set of tracks is the same part as the one above/below it or if it is a new part. And another little added benefit... it helps keep the track names short, which is really helpful if using a controller with scribble strips like a C24 or an ICON. Hope that helps!
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
Sent from my Droid using Tapatalk
Re: Vocal Tracking
There is a old story about a famous Producer/Engineer and an 80s power group were the lead guitarist walk into the pub after a day in the studio and complains about spending all day playing the same note to a Sony 3348 save reel.
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Re: Vocal Tracking
You can also change he colour of the traxk and fader. Go to the "Colour pallet" under windows. You can all your vox, guitars etc all one colour.
data is not data unless it's backed up in three places! |
Re: Vocal Tracking
This way when looking across the control surface with all the tracks being shown, I can easily spot the Aux tracks from the Audio tracks... So it would be like LEADVOX Sub leadvox V1 leadvox P1 etc... As you play around and work on more sessions you'll start to come up with your own system that will probably be a combination of a bunch of other people's systems. Like for example, a chief engineer at a studio I used to work out of would solo safe the Aux tracks but leave the audio tracks normal. For me, since I use the Aux tracks for mixing moreso than the audio tracks. I flipped his way of doing it for my own workflow. so I solo safe ALL the audio tracks in a group, but I don't solo safe the Aux. That way I can solo the Aux and hear all the tracks that belong to it. Now with VCA tracks this is less of an issue...but I came up with this workflow long before PT added VCA tracks to HD... and since LE doesn't have VCA tracks, this workflow might work for you (or some variation of it). Once you get a system going, 30 to 40 tracks isn't so bad. I think the biggest music mix I've done was somewhere between 130 to 150 tracks. For films, forget about it... I've mixed films before where I had over 100 tracks in each protools system and I'm controlling/mixing from 2 or 3 protools systems simultaneously. And there was a second guy there with me also mixing using a couple more protools systems! Being organized and coming up with your own "method" or workflow is important. You always want to put the same tracks in the same spot for every project. It makes finding things quicker which in turn helps make mixing faster. For me drumset is always the topmost/leftmost tracks in the session or on the console/control surface. After that percussion. After that any sound effects or music design. after that Bass guitar. After that any regular guitars... after that any keyboards and synths... after that any strings... then brass... then woodwinds... then lead vocal, then adlibs, then doubles, then background vocals. And within each section I usually try to arrange the tracks from low freq/pitch to high freq/pitch. so for example, with guitars, low "chug" guitars would come first, and then to the right would be higher pitched or shimmering guitars. For drumset, it's always kick, snare, OH, HH, Toms, Room. For Strings it's always Contrabass, then Cellos, then Violas, then Violin, then room mics... but if there are multiple passes I keep each set together following this layout. I don't put contrabass 1st pass next to contrabass 2nd pass. For me it just makes more sense to keep each pass together instead of putting all the different passes of each instrument together... and so on... As you keep doing this you'll start to find your own way of doing things. For example I know some guys that always like to have the bass guitar track right next to the kick drum track. I don't like doing that, but for some guys it works really well... everybody has their own system of organization that makes sense to them. Over time you'll find yours.
Re: Vocal Tracking
Thus far, my work-flow consists from top to bottom: Vox Guitars Bass MIDI Drums For some weird reason I like to stack Aux tracks on the top of the source tracks from which they're sucking the juice from. I view this "order of tracks" as a foundation, drums and bass "carrying" the load. It seems to work for me as of now. I started following your guidelines and made individual tracks, then I started overwhelming my self because I was making tracks like... PreChorusBG1, PreChorusBG2, VerseVox1, VerseVox2, ChorusVox1, ChorusVox2... following with stereo auxes for backgrounds, and mono auxes for Leads and Verses. Then I said, "hold on, hold on", I need to simplify this. I don't need more tracks than necessary, right? The simpler the better. Again, I'm going to follow your guidelines and keep it simple at first. I like the idea of sending background vox to stereos, and leads to mono, I might not have ever thought of that! I'm going to get back at it, and do my best! Thanks again man!! I wish I had a job like yours, (assuming that is your job) working in a recording studio like that. One day I would absolutely love that! I work road construction, but my passion lies heavily in drumming, singing, and now guitars and tracking!! I spend about 4 hours a day in my little home studio, and I only become more captivated each session!
Re: Vocal Tracking
Fuuuuuuudge!
You should make some "Killa" templates... I just had a flashback of the guy I interned under who had a "master" piece of "masking) tape that we laid down and transferred the info to the new sessions. Most of my experience to where instruments were tracked was relative to the physical location on the recording tape. No kicks on edge tracks or something like that if my memory even works at this point. I like the capital letters idea since my earliest DAW experiences were void of color choices.
Digidesign 003R+PT 2020.12.0, Gigabyte GA-Z97X, CPU INTEL i7-4790 4.0Ghz, CORSAIR DOMINATOR 16GB; ATI Radeon™ HD 5450 PCIe Multiple WD Caviar Black 2Tb Spinner Drives; 1 PPA 80GB 1394 Firewire Oxford 911 PYRO PCI64R2 3 Port Firewire Card (PCIe) Antec 300 case. PSU 600W, Windows 10 Home. |
Re: Vocal Tracking
Derek is da man! Nice!
Start to use labelling conventions that you like, and keep them consistent. I do it like this: lv is lead vocal sLV is the mono aux that lv is routed to vLV is the VCA that controls all the lv's 2MIX is my stereo aux master mix buss that all tracks are routed to MAINS is my master fader **MELO** is the name of the bus I use to print Melodyne to a new audio track **PRINT** is the name of the bus I use to print my mixes to a stereo audio track **1 - M** is the name of the bus I use to print miscellaneous tracks to a mono audio track (I have 4 of these **2 - M**, **3 - M** and so on) **1 - S** is the name of the bus I use to print miscellaneous tracks to a stereo audio track (I have 2 of these) Stuff like that. Once you get used to it, you'll be flying around the session. EDIT: I forgot to mention something I've just started using. All instrument tracks are named with an "i" in front, which won't give me an error when I name the audio track I print it to. So, iPiano would be the track with the VI on it, and Piano would be the printed audio track.
Vocal Tracking | firsty33 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-11-2010 05:41 PM |
Vocal Tracking? | Bluetide | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-30-2003 07:30 AM |
vocal tracking with art mpa pro | jdavis74 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-30-2003 02:21 PM |
chorus n vocal tracking | phanatik | Tips & Tricks | 6 | 03-06-2003 09:39 PM |
vocal tracking | SNAPPER | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-16-2000 09:52 AM |
