v drums with eleven rack
Trying to determine the best way to sound my new Roland td11 kit without having to open pro tools. What do you guys find works best? I am also using M-Audio BX5 monitors. Thanks
Re: v drums with eleven rack
If the Eleven Rack is your only interface, that's going to be difficult, because you would be using the Eleven Rack in standalone mode, and in that mode you can only use the single guitar input. You would probably need a small mixer going directly to your monitors, or another audio interface that allows a standalone mode of some kind (many do not).
This may be worth a try. If the Roland brain has a headphone out with a volume knob, get a cable that is TRS on one end, and splits out to a pair of TS plugs. Assuming the Eleven rack feeds the speakers via XLR cables, plugin the drum headphone out to the quarter inch inputs(I do this with my Motif es8, feeding BX-5's). Turn up the headphone out on the Roland to hear it straight thru the speakers. Turn the headphone knob off when you work thru Pro Tools.
Another option is a monitor/source selector like Mackie Big Knob or Presonus Central Station(what I use in my setup) as that will allow you to select what source feeds the speakers.
I think this is not what the op wanted to do because NST7 and I are assuming the op has the v-drums connected to the line ins on the 11R. |
Come to think of it, I used to do this with KRK Rokit 5's and the headphone out of my Roland TD-10 kit. I had the speakers mounted on the rack and could listen to the Roland kit without Pro Tools, or turn the headphone volume off and listen to Pro Tools audio(including the drums from the session). Maybe not the ideal setup, but it worked and sounded great, and never caused a problem over the 3 years I had it setup that way(no longer using the Roland kit). In my current setup, I have BX5's setup over the Motif, Event ASP8's at my workstation and I can switch PT to play thru either set of speakers, with or without a sub(but the Motif direct connection bypasses the sub). monitor/source selector makes things even slicker(Presonus Central Station in my setup) but I am bypassing that for my particular setup due to ground loop issues.
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? | Rongpat | Eleven Rack | 8 | 02-11-2014 07:42 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
Can I use my Eleven Rack to record drums? | alexdude777 | The Drum Room | 11 | 01-14-2012 09:47 PM |
Eleven Rack and V-drums | Pont68 | Eleven Rack | 4 | 01-30-2011 09:00 PM |
