Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 07-09-2014, 04:29 AM
rebelde45 rebelde45 is offline
Default avid mini box 3rd generation
hi, my protools 9.06 doesn't recognize avid mini box 3rd generation; I use it in my PC to hear music, so it's working; I've uninstalled the old one and installed the new drives, bur still not working,,, here are some print secreen, ty for you help...
Old 07-09-2014, 09:37 AM
There is no "Mini Box" Do you mean the 3rd generation Mbox Mini? Or just 3rd generation Mbox? Post a photo if unsure. Was it working before you uninstalled the previous driver? What was changed just before it stopped working? Remove it as the system sound device in Windows and make sure no other application is using it.
What exact driver version are you installing. Are you following the install instructions and doing this with the interface disconnected? Have you fully optimized your computer, especially disabling power management and USB power management? Start at the "Help us help you..." Link above on this and every other DUC page.
Old 07-10-2014, 12:51 AM
Default Re: avid mini box 3rd generation
yes, I mean 3rd generation Mbox Mini; after 8 hours I've decided to uninstall pro tools and install it all from the begining from the original CD's; the problem is the driver I've downloaded from your site wasn't working... I'm using Mbox Mini with my Windows and works perfectly: I didn't touch the Power management, never had problems with that... I don't know what was changed just before it stopped working, just didn't recognize Mbox Mini ... thank you for your "help", take care
Old 07-10-2014, 07:45 AM
It's not my site. Did you install the 1.1.7 driver? That may work with Pro Tools 10 and 11 only, the release notes are ambiguously written. Did you try the 1.0.8 drivers?
You need to follow the install instructions for Pro Tools and do those power management and other optimizations or you will run into other problems.
You also want to be on a recent version of Pro Tools 9 like 9.0.6 or you will likely hit other known problems.
Mbox mini 3rd generation PT 11.0.3 and Mavericks Elnico50 FireWire and USB Audio Interfaces (Mac) 11 12-17-2013 04:54 PM
Avid Mbox (3rd Generation) and USB 3.0 BassLineEmpire FireWire and USB Audio Interfaces (Mac) 0 10-11-2013 01:45 PM
Is 2nd Generation Mbox2 mini complatable with Mountain Lion 10.8.2 ? DJtrademark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-03-2013 02:49 PM
Second generation Mbox 2 Mini and OS X 10.8 mountain lion kattskralle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-19-2012 10:19 PM
Avid Recording Studio vs Avid MBox Mini 2 vpg0002 General Discussion 7 03-20-2011 07:52 AM
