Old 10-01-2012, 11:19 AM
legasafe legasafe is offline
Default Importing clips in Pro Tools 10 / clip naming
Hi all,
I'm probably missing something here but on PT 7-9 when I "open with" a .wav the file name became the region name in Pro Tools.
However when I "open with" Pro Tools 10, the clip/region name is something else entirely, as though it has been saved as metadata.
Sometimes when I'm editing a series I will make a toolkit and rename all of the files something like "atmos - sues kitchen -" etc. which can be very quick in the finder, however if I then proceed to "Open With" PT 10 I lose all of my renaming...
Any ideas?
p.s. dragging and dropping seems to keep the filename but I have a script that does all this in batch which requires the use of "open with".
Has anyone else noticed this? It's very possible that this isn't a feature of PT10 and that I've just got a setting changed somewhere.
Any help would be really appreciated!
Old 10-02-2012, 02:10 AM
Default Re: Importing clips in Pro Tools 10 / clip naming
Has nobody come across this/have any ideas?
Old 10-03-2012, 05:36 AM
Felix Rost Felix Rost is offline
Do you mean the right click "open with"?
Protools says: "This is not a valid Pro Tools session file"
http://felixrost.de
Old 10-20-2012, 05:44 AM
Yes that is exactly what I mean, however you need a PT session open first in order for it to import the audio.
Does that work for you?
HTML code is On
PT10: Naming & Coloring Clips TaoMokoda Windows 6 04-16-2017 08:54 AM
Naming of clips when audio file ends with a number John Link macOS 5 06-02-2013 04:36 PM
Clip gain issue when importing AAF in Pro Tools 10 chefbrody macOS 4 03-28-2013 07:53 AM
Clip naming dannymeltzer macOS 0 12-02-2011 02:30 AM
PT/AV XL 5.1 Spotting & naming video clips Robin Hollings Post - Surround - Video 0 05-07-2001 04:23 PM
