Old 08-09-2010, 11:53 AM
Matze1985 Matze1985 is offline
Default Video Satellite PT 8.0.4 Video Problems
HI,
my system: Mac Pro Pro Tools HD 8.0.4
Mac Pro Pro Tools LE 8.0.4 Satellite
My problem is, when I press play in Pro Tools and stop it, Pro Tools doesn't show me the frame which would be normally at this TC. It shows me the frame, which was the first frame of playing. The timecode does not jump, like the video. When I play it again, the video runs normally.
When I used PT 8.0.3cs2 I didn't have this problem.
I don't know what I can still do.
Does anybody have the same problem?
If you need more information for answering, please ass me.
Thank you for your help.
Matze
Old 08-09-2010, 11:58 AM
Nathan W. Nathan W. is offline
Default Re: Video Satellite PT 8.0.4 Video Problems
I have the same problem, it's only when I click on the cursor at that time code does it show the correct location. I believe this is one of the several video bugs that hasn't been addressed by Avid yet.
Nathan
Old 08-09-2010, 12:02 PM
Hi Nathan,
thank you for answering. So we can hope that AVID will fix this bug as soon as possible.
Are you doing anything for working normally?
Kind regards,
Matze
Old 08-09-2010, 02:41 PM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
Evergreen Audio Design Group
Are you sure you didn't have timeline insertion follows playback enabled?
If you have this enabled, the insertion point jumps to the stopping position. Otherwise, the stopping position is where you started.
Old 08-09-2010, 03:02 PM
I have tested all possible buttons. There were no success.
Old 08-09-2010, 03:10 PM
Yes even when Timeline Insertion follows playback is enabled. Playing video then pressing stop, the video will always go back to it's starting position. ONLY the video does this though not the actual cursor on the timeline (whatever that line is called). Producers get confused because they think I went back to that position when all I did was press stop. It's weird.
Old 08-09-2010, 04:22 PM
JMDNYC JMDNYC is offline
I've found it works better if the satellite is in Slip mode, not Grid mode. Doesn't explain what you're experiencing, but it does make frame advancing and stopping on a certain frame more accurate
Old 08-09-2010, 11:55 PM
I've the same problem when the satellite works in SLIP mode. There are no differences between SLIP and GRID.
Old 08-10-2010, 09:05 AM
Thank you for your help, but does anybody have an other answer, how to solve this problem?
Old 08-10-2010, 01:01 PM
this is frustrating to me to because the only way to get around it is to use your cursor to click where you pressed stopped so that satellite shows about the correct location. Doesn't matter the mode I'm in on either system always does it.
HTML code is On
"Video Satellite Option 1.0 - Authorization Error" - without Video Satellite Matts macOS 7 06-29-2011 08:32 AM
sync problems with Video Satellite LE CD Productions Post - Surround - Video 5 05-16-2011 01:22 PM
Video Satellite LE on a Mac G4 problems CD Productions Post - Surround - Video 9 04-07-2010 08:17 AM
Video Satellite LE and 8.0.3 problems? Brandonx1 Post - Surround - Video 6 01-17-2010 10:54 AM
Video Satellite LE Sync Problems jmattchan Post - Surround - Video 12 08-22-2009 09:45 AM
