Old 10-15-2005, 08:54 AM
hornedrum hornedrum is offline
Default roland TD3 with PT and reason
Hi there,
Just bought a Roland TD3 sound module and want to use it with MIDI and rewire to trigger Reason's Redrum.
Most of the sounds the TD3 creates are outside the C1 - C2 octave so don't triger any sounds in redrum.
I only have one pad right now as input for the TD3, but it doen't seem to like it when I try and change the MIDI note number for each pad: nothing changes.
Is there any way I can re-route redrum for midi input so I can trigger every sound from the TD3.
Or is there some way of changing midi mapping(?) in PT to reflect this?
I know I could record a midi track then manually change each BD, SD onto the right note, but that defeats the purpose of buying the TD3: ease of playing in kit parts!
Any help gratefully appreciated!
Cheers,
Andrew
Midi- Roland Keys playing EZ Drum and Reason at same time sweepsr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-21-2010 07:34 AM
Triggering Reason adapted with Roland TD-6v?? ian Bourgal MIDI 7 01-07-2008 04:07 PM
click anomalies, using Roland TD-10 to trigger REASON Jenk2k MIDI 4 10-24-2007 09:16 AM
roland vg-8,gk-3pickup,reason, digi002r question JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-03-2004 04:03 PM
Reason for Roland Ke productions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-22-2003 01:03 PM
