Old 04-10-2005, 05:46 AM
Fladlien Fladlien is offline
Default Limiter or Compressor?
This is a silly newbie question, but I was wondering when it is better to use a limiter than a compressor. I know there are certain applications where a limiter works better, and I have a vague idea of such appliciations, but I'd like to hear some input on the subtle issues of using a limiter instead of a compressor. Any input will be appreciated. Thanks.
Old 04-10-2005, 07:40 AM
Default Re: Limiter or Compressor?
It depends on what you need to do to your signal. Say you have a player that is fairly even level-wise, but every once in a while he slaps his bass, or a singer seems to always spike you when he sings a word starting with the letter P. Use a limiter to catch those peaks but otherwise nat affect the sound. Now a compressor is more for evening out an inconsistant level. At the upper end of signal, the compressor "holds back" the level by the ratio amount(above threshold at 4:1, the signal would have to be 4 db hotter to get a 1 db increase in output or volume. 8 db above threshold would net a 2 db increase). Think of it like this, a compressor squeezes the dynamic range(soft to loud) into a smaller window. A limiter is more like a brick wall where the signal simply can't exceed a certain level.(hence the term "brick wall limiter"). A compressor is good for fattening up a sound while a limiter is good for preventing a digital clip. This is over-simplified but at least will get you thinking. Check out some recording technique books as many have great(and likely better) explanations.
Old 04-10-2005, 09:52 AM
Chris Cavell Chris Cavell is offline
Rob,
Traditionally, any compressor with a ratio setting of 10:1 or greater is considered a limiter.
Cheers,
Chris
Cavell Studios
Old 04-10-2005, 10:24 AM
dissolve dissolve is offline
Someone told me a limiter was a compressor with a 100:1 ratio, I don't know if that's entirely accurate or not
10:1. A limiter is a compressor whos compression ration is 10:1 or higher.
One way is to think of a compressor as an envelope modifier. You can change the attack, decay, sustain and release characteristics of whatever it is you're compressing. A limiter is like a loudness button. It will chop of the transient peaks and make it sound "louder" buy raising the overall energy level.
Best thing to do is understand and learn how they work, do alot of experimenting to learn the sound, and then do alot of listening to mixes old and new to hear how they're used and how you want to use them.
I'd avoid a limiting on a Master 2-bus while mixing. Save that for the mastering stage if it's needed.
Master Fader Limiter/Compressor SSL Compressor mesa3077boogie Pro Tools 9 8 07-11-2011 08:15 PM
Compressor/Limiter Dyn III GuyPicks Pro Tools TDM Systems (Mac) 4 09-22-2010 02:50 PM
Compressor or limiter xterraguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-07-2009 08:45 AM
DYN III Compressor / Limiter Elton Hyland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-29-2008 06:39 AM
limiter / compressor Moses Presley General Discussion 5 02-08-2003 10:33 PM
