Old 03-07-2006, 05:21 PM
jackp jackp is offline
Default output to my tascam cdrw 2000 ?
I have my tascam cdrw 2000 coming into the 002r via coax both in and out from the 002r
on a master fader I can't get no input signal to the tascam to do a quick mix
What Aim I doing wrong ? Thanks Guys
Mac Pro 8 core Protools 10 HD 4 Accel PCI with Magma, C/24 with 2 192 I/O
Isochrone clock
Old 03-07-2006, 05:40 PM
spkguitar's Avatar
Default Re: output to my tascam cdrw 2000 ?
Have you checked your I/O setup?
Are you setting the main outputs to the S/PDIF? Or are you bussing the output there somehow?
Old 03-07-2006, 06:31 PM
Hey Spkguitar I have the coaxil coming in and out spdif left and right on a aux track ,I got signal coming into the aux but none going out to the tascam cdrw 2000. Is there and easier way? thanks Jack
Isochrone clock
Old 03-07-2006, 06:56 PM
spkguitar's Avatar
Page 585 of the Reference Guide
Old 03-09-2006, 04:33 AM
Hey pkyguitar I can set every channel the s/pdif out and I get signal. Isn't there and easier way than thatIf have a master headphone mix going out to a headphone amp looks like you assign a master or and aux to go out to a stand alone cd burner Thanks so much
Isochrone clock
Old 03-09-2006, 10:08 AM
Default Re: output to my tascam cdrw 2000 spkguitar ?
Can anyone explain thanks Jack
Isochrone clock
Old 03-09-2006, 10:52 AM
SumOdRsn SumOdRsn is offline
You can Alt, right-click on the output of one of the tracks and then select Analog 1-2 and it will output to both analog 1-2 and SP/DIF. The output will look like SP/DIF+. That way it will be mirrored on your headphones and sp/dif outputs.
Help! Latency problems on Pro Tools 10 with Tascam US-2000 esetheridge Pro Tools 10 0 07-22-2013 02:05 PM
Tascam US-2000 works with Pro Tools 10? marcnyc Pro Tools 10 1 05-25-2012 09:04 AM
setting up a tascam cdrw 2000? jackp Pro Tools TDM Systems (Win) 1 05-13-2009 07:17 PM
Tascam CDRW 750 vs. Standard CDRW Digitalkidd Pro Tools TDM Systems (Win) 1 05-24-2005 11:08 AM
TASCAM CDRW 750 vs. ITB Digitalkidd Pro Tools TDM Systems (Mac) 1 05-22-2005 09:59 PM
