Old 12-19-2013, 05:03 AM
cheney5 cheney5 is offline
Default Slimming down the PT system. Mac Mini & Thunderbolt peripherals
Hey guys,
Im running a 4/5 year old Mac Pro with PT10, 003 desk and Avid Mojo(analogue) at the moment at home. I have a bigger rig set up at work (HD3, 192, SyncHD, 192d, MicPre & D-Command). So my home setup is just used for editing, prep work etc.
So...
I am looking to shift my old MacPro and am thinking of the following set up. Mac Mini with 8gb ram, thunderbolt pci expansion chassis with a pci firewire card for the 003 (& possible native card long term), using the firewire800 for the mojo.
How do i go about getting dual monitors on a mac mini?
Has anyone used a thunderbolt expansion for pci firewire use?
Also, Has anyone used a thunderbolt SATA harddrive caddy? Do we think i can have my media drives linked via the pci chassis to the mac Mini? Or will pro tools have a fit?
Any help would be great!!
Thanks
Matt
Old 12-19-2013, 07:23 AM
reichman's Avatar
reichman reichman is offline
Default Re: Slimming down the PT system. Mac Mini & Thunderbolt peripherals
Seagate GoFlex Desk Thunderbolt drives have been great for me. I really like the system on my home system.
Blackmagic has some cool toys that might motivate you to drop the Mojo. Good luck figuring this out. I think a lot of studios are going to go down a similar path.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 12-19-2013, 01:07 PM
BroomPole BroomPole is offline
I've been using Mac Mini's to replace a lot of simple process / QC computers requiring access to Fiber SAN drives with great success. It's surprising how well they preform.
Dual monitor support it quite easy. They come with a HDMI port and a HDMI to DVI adapter. For 29 bucks you pick up a additional Thunderbolt (Mini Display) adapter to DVI and you have dual monitor hookups.
For drives I've been having some great success from USB3 drives (Way cheaper then thunderbolt) and if your not looking at raid drives there no reason for the extra cost. A single spinning drive will come no where near fast enough to max the bandwidth of thunderbolt (or USB3) for that matter.
cheers
Kevin
Old 12-20-2013, 12:12 AM
Thanks guys.
The main issue I have is that I have two peripherals that require a FireWire buss. The 003 and the mojo. And I want to use the thunderbolt for the second display by the sounds of things.
It's looking more and more likely I should by a newer Mac Pro at the mo. The mini just doesn't have the outputs I need.
Old 12-20-2013, 07:07 AM
quadraphonics quadraphonics is offline
You would have the outputs you would need it you would look at something like the Belkin or Sonnet TB break out boxes.
Old 12-20-2013, 07:16 AM
Ah ha! That the kinda thing I need. Now all I need to know is whether the Belkin breakout box can handle the 003 and second monitor?
Don't suppose any out there has tried such as foolish errand?
Old 12-20-2013, 09:59 AM
Jay_uk Jay_uk is offline
Originally Posted by cheney5 View Post
Thanks guys.
Matrox do various boxes to suit
http://www.matrox.com/graphics/en/pr...o/displayport/
Old 12-20-2013, 12:44 PM
The throughput on a TB connector far exceeds the demands of DVI and FW. There shouldn't be an issue. I believe that the Belkin boxes are sold in Apple stores. If it doesn't work for some reason I am sure they would take it back.
Randall
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 12-20-2013, 02:14 PM
Thanks Randall
Old 12-23-2013, 09:26 PM
fork-media fork-media is offline
yeh but will they take the mac mini back?
cos u sort of commited once u bought that!
I am thinking of doin similiar - but my mac pro is 2007 (or 2008 )
can it really handle it?
I would love to cut my power bill too!
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
HTML code is On
We need a Thunderbolt HDX system Electrox Pro Tools HDX & HD Native Systems (Mac) 185 02-07-2018 04:19 PM
Mac Mini dual monitor with HDN Thunderbolt Tim R. Pro Tools HDX & HD Native Systems (Mac) 13 05-17-2013 08:44 AM
New Mac Mini with PTHD10 through Thunderbolt delenes Pro Tools HDX & HD Native Systems (Mac) 4 06-20-2012 11:10 AM
slimming down a PT session therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-20-2009 04:16 PM
Slimming down sessions for archiving D Pinder Tips & Tricks 15 09-23-2000 02:01 PM
