Old 11-17-2004, 04:48 AM
ndawula ndawula is offline
Default Native Instruments
I've just purchased Native Instruments and I wanted to know how to play them via a midi keyboard. I've got a digi002 mixer, a midi lead and Pro tools. Do I need a seperate midi interface?
Old 11-17-2004, 07:14 AM
mindnoise mindnoise is offline
Default Re: Native Instruments
WHAT??? your purchased NI??? The WHOLE company??? And you want to control THEM (the emplyees(?)) via MIDI commands?
this is the funniest post I read in a long time, this is great!, sorry for not being helpful here,
I never owned a company before
last: PT11.3.1
Old 11-17-2004, 07:32 AM
pk_hat pk_hat is offline
Read your Digi002 Quick-Start Guide.
Whatever NI instrument you bought, there should be a basic setup guide early on in the manual. It's pretty straightforward stuff. Choose your midi channel input and device, choose your sound outputs and you're off. You don't need a separate midi interface, you should be fine with the 002's midi I/O.
www.myspace.com/krou
Old 11-18-2004, 11:27 AM
I've got Komplete 2 and the reigstration process is a pain. We were sold an ilok registration key with the instructions 'Put it in and it will work' We were not given any instructions. The ilok site was less helpful.
Old 11-18-2004, 02:10 PM
I thought NI uses their own ONLINE registration and not a iLok protection
So IF it is a real iLok you may need to register with www.ilok.com
You create an account without registering your iLok.
but if you register your ilok you are not able to remove it /sell it anymore. but you can see the authorizations on it.
But you should download the the ilok ´driver´ from within your account .and install it. then your stick you ilok into the usb port and the software should recognize it.
again: that NI uses ilok is completely new to me, and nowhere on their website I can find a hint of ilok.
and perhaps this helps some more:
http://www.nativeinstruments.de/inde...yprotection_us
and
http://www.nativeinstruments.de/inde...kompletefaq_us
regs
last: PT11.3.1
Old 11-20-2004, 10:16 PM
music4u2 music4u2 is offline
Hi there,
I'm also a NI Komplete 2 Bundle owner and it sure DOES NOT need an ilok to register.
The registration is quite simple and is done all online. They even let you authorize a laptop as your remote unit.
You don't need a midi interface , Digi 002 already have it's own midi ports.
Just configure your Midi Keyboard as your master and assing it to the input of the midi track.
In order to use the NI modules you should first create an Aux track and insert ( on inserts of course) the instrument of you choice there.
Than create a midi track and assign the output to the mudule's midi channes( 1 - >16)
Make sure the aux track with the module level is set to Odb you should be able to hear the sound of it.
hope it helps,
Iuri
Native Instruments - xfer fee for instruments? YYR123 Virtual Instruments 3 10-13-2013 05:47 PM
native instruments beright macOS 7 01-19-2011 10:32 AM
NAtive instruments ferry5 Virtual Instruments 9 04-26-2010 01:28 PM
Native instruments, help orenfarber 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-04-2002 01:31 AM
Native Instruments Musichead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-23-2002 01:45 AM
