Old 09-28-2019, 01:05 PM
shaft shaft is offline
Default Changing pitch of a song
I have a song that I want to raise the pitch of the bass a half step. I have tried using avid pitch 2 but it sounds terrible. Is there a plugin that you would recommend for changing the pitch of the bass?
Old 09-28-2019, 01:40 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Changing pitch of a song
Have you tried changing pitch with Elastic Audio?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 09-28-2019, 03:00 PM
amagras amagras is offline
Elastic audio should do a good job with a bass, make sure to try the different algorithms available and compare which one sounds better, specifically monophonic, polyphonic and x-form which are the ones what can handle pitch.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 09-28-2019, 06:22 PM
IRCAM TS
UVI Falcon (not cheap)
Jack
QAPLA!
Old 09-29-2019, 06:09 PM
Elastic Pitch is worth a try(but only the Polyphonic algorithm allows for pitch change). Serato Pitch 'n Time is excellent for this(they may have a free demo period so you can process your bass permanently because it works in AudioSuite for this). Zplane's Elastiq is another good one(but start with Elastic Pitch because you already have it). Half and whole-step changes should be fine. The more expensive options tend to maintain better sound quality with larger changes
Old 09-30-2019, 04:16 AM
It's a bass, monophonic should handle it too if it doesn't play chords
amagrasmusic.com
Old 09-30-2019, 07:39 AM
JFreak's Avatar
JFreak JFreak is offline
EA monophonic should do the trick for bass instrument, but I still prefer to do all my pitch tweaking on Melodyne. Not the cheapest tool, but the results don't make my ears turn around.
Janne
Old 10-07-2019, 07:33 PM
chrisdee's Avatar
chrisdee chrisdee is offline
Xform or Serato Pitch n Time works ok for me. If its only a half step EA would probably work aswell.
For more extreme stuff none of the pitch plugins I have tried is good enough. I either loose transients or they screw the quality.
Old 10-07-2019, 08:42 PM
Guess I need to dig deeper on this. I was under the impression that only Polyphonic would allow the pitch change
HTML code is On
How to Increase Song Tempo without Changing Pitch? dts.music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-27-2008 02:46 PM
changing tempo without changing pitch Sharabelle Pro Tools TDM Systems (Mac) 3 02-10-2007 05:19 PM
Changing BPM on a song MikeSoloway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-16-2006 12:25 PM
changing the key of a song... dkinman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-31-2005 07:58 PM
Changing Pitch Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-02-2004 08:31 AM
