Old 09-29-2016, 04:57 PM
cshaw cshaw is offline
Default Clip effects not working [SOLVED]
Perhaps I'm missing something but I'm running PT 12.6 HD on a HD Native card and I can't enable clip effects. Does it require a HDX/DSP card?
I have a HD Native card which I got from trading in my old TDM rig 6 years ago and am running HD via Firewire with my Apogee Ensemble.
I've trashed prefs etc…
Any ideas?
Old 09-29-2016, 05:06 PM
TrentWilliams TrentWilliams is offline
Default Re: Clip effects not working
How are you trying to enable clip effects?
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 09-29-2016, 05:22 PM
Default Re: Clip effects not working [SOLVED] duh!
Embarrassing…
I always test my new installs with a test session that I have that contains a bunch of loops. I opened it up 12.6 to check out clip effects and it would not engage.
Turns out that I was trying to engage it on a track that where the clips were grouped - d'oh!
However I did notice that clip effects are turned on by default on every clip in a session. That could get weird although it has the added advantage of having a phase switch on everything…
Old 09-29-2016, 06:05 PM
Carl Lie Carl Lie is offline
I did notice that the comp/gate section does not show the level of audio in the line like it does in the channel strip. Can't visually see the level of compression or where its kicking in.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 09-29-2016, 06:31 PM
mattrixx mattrixx is offline
Mm, yes I noticed that it didn't work on grouped clips.. be nice if it did!
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 09-30-2016, 05:22 AM
Drew Mazurek's Avatar
C
Expect to see this added in a future update.
www.drewmazurek.com
What in the world is 'instant on Sound Effects' and how can I get rid of it? [SOLVED] EricWillhelm Pro Tools 12 7 11-30-2017 04:29 AM
AudioSuite Plugi-ns won't process Clips, not rendered to Track [SOLVED] DetroitT Pro Tools 12 16 04-01-2017 02:48 PM
Clip Corner Question [solved] Neurosis Pro Tools 12 3 07-31-2016 05:36 AM
Nudge clip gain broken 12.5.2? [solved] johan2006 Pro Tools 12 4 07-13-2016 08:46 AM
Clip slide causing echo ? [solved] K Roche Pro Tools 12 4 02-04-2016 10:03 AM
