Importing Impulse Responses to IR1
I just received a bunch of custom impulse responses in .wir form. I can't seem to figure out how to get IR1 to recognize them, other than importing every single impulse response manually. I thought I could just drop them all in the IR1 folder but no luck. Any ideas?
On a side note- any way I can use the .sdir impulse responses from Space Designer in IR1? Thanks! |
Re: Importing Impulse Responses to IR1
there is a folder in the waves application folder if you drill down far enough called "acoustics.net" and the IR plug seems to use that as a watch folder for loading up new impulses, you could try dumping them in there, although I have never tried this.
hmmm can't find that anywhere...
Also looking for an easy-to-load convolution reverb for pro tools. IR1 seems to require multiple impulse responses per preset to work as intended; Not sure why?
Although not perfect, have you tried TL Space?
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
I think you need preset files (.xps) in addition to the .wir files. I put mine in the "Waves/Plugins/IR 1Impulses V2" folder. If you don't have the preset files to match each .wir, then yes you will have to import them one at a time to create the presets.
This is all from memory, but I think thats how I did it.
~Will |
Importing Altiverb Impulse Responses Into TL Labs Space | Siegfried Meier | Pro Tools TDM Systems (Mac) | 7 | 03-26-2013 06:21 PM |
Impulse Responses | 2hip2b4real | macOS | 1 | 05-16-2012 08:05 AM |
Can’t access effects editing window in Structure when importing wav impulse responses | rique000 | Virtual Instruments | 7 | 05-29-2009 04:32 PM |
Importing impulse responses in TL Space? | Holly73 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 02-10-2007 01:44 AM |
my impulse responses | Chris Cavell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-04-2004 08:08 AM |
