Old 01-16-2014, 03:24 AM
Sjoberg Sjoberg is offline
Default Edit Selection Follows Clip List Selection not working
Hello!
I'm in the process of cutting and editing a huge amount of sounds for a project.
I usually use the Auto Rename in the clips list when doing this.
But for some reason when i select clips in the timeline it wont select the same clip in the clips list which is extremely annoying.
Anyone know what the problem could be?
Win7 Ultimate 64-bit, Pro Tools 10, RME Babyface.
i5-3570 3.4Ghz, 16GB DDR3 665MHz, MSI Z77-G43, GTX 680, 1TB Samsung HD103UJ.
Old 01-16-2014, 06:26 AM
Stig Eliassen's Avatar
Default Re: Edit Selection Follows Clip List Selection not working
Which version of PT 10 is this?
Are you by any chance using the Object Grabber (click'n'drag the marquee to select)?
Old 01-16-2014, 10:28 AM
joachim's Avatar
joachim joachim is offline
Even though you have checked : Setup - Preferences - Editing - "Clip List Selection follows Edit Selection" ???
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 12-04-2020, 12:38 PM
oldskool oldskool is offline
I am having this same problem in a session in PT2020.11U. This particular session was imported from an AAF and is audio for a feature film. The "clip list doesn't follow edit selection" problem does not manifest in other sessions on the same system. Preferences for "Clip list selection follows Edit selection" are properly selected.
Strangely a small subset of the clips in the edit window do select their counterpart in the clips list. I can't figure out what is unique about these particular clips.
Not having this workflow is going to make this project almost impossible. Has anyone solved this?
Move Edit Selection Not Working! Help!! Monk Pro Tools 10 5 05-28-2013 07:51 PM
link timeline and edit selection not working blackdognove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-06-2011 01:17 AM
PT 7.4 HD: Link Edit- and Region List-Selection Smico Tips & Tricks 2 10-14-2011 02:54 AM
link timeline and edit selection not working binetron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-14-2007 01:35 AM
Edit Selection Follows Region List Selection->NOT! alteregg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-14-2006 03:40 PM
