Old 01-28-2010, 05:57 AM
evon evon is offline
Default sharing sessions across the internet....
Can I share my recorded session(s) file with another producer across the internet? Another words, say I recorded some beats with my pro tools le and I send the file that I recorded in pro tools le to another music producer to have him/her record key/synths into my session file while this music producer uses pro tools m-powered.
evon
Old 01-28-2010, 06:15 AM
1ace1 1ace1 is offline
Default Re: sharing sessions across the internet....
That should work fine. If it is a protools session it should open into any version of PT be it LE, HD or mpowered. Obviously there will be massive compromises if trying to open an HD session on LE, but LE to mpowered should be fine.
A:)
I Love Audio!!!
Old 01-28-2010, 07:02 AM
se.audio's Avatar
se.audio se.audio is offline
Make sure you use the same plugins, etc... also, make sure your file is self contained: that is that the disk allocation for each track is in your session folder and all audio tracks are in there. The just Zip the whole lot and upload it via getdropbox.com that's the easiest solution... And now that I come to think about it, with get drop box you don't even have to zip it, meaning you can only download the parts that he's added and you'll be ready to go...
se.audio
Old 01-28-2010, 10:09 AM
thanks guys for your reply. I will do that.
evon
Old 01-28-2010, 10:10 AM
bfx bfx is offline
Just for the sake of pragmatism:
If it's only a beat you might be easier off just sending a bounce as mp3. That is as long as your collaborator is not suspected to fiddle around with plugins, of course. You could also send stems if monitor mixing is an issue.
Mac Pro 8-core 2.26 | 6 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8
MacBook Pro i5 2.3 | 4 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8
Old 01-28-2010, 11:59 AM
While this works, be forewarned that converting from mp3 to wave and back can sometimes put minute timing errors due to the conversion/compression.
Old 01-28-2010, 12:32 PM
bfx bfx is offline
Uh, didn't know about this! Thanks albee...
Internet Sharing Large Files/Folders? wdjudd Pro Tools 10 6 01-28-2013 06:37 PM
Sharing sessions - PT 6.0 HD to PT 5.1 LE kingfly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-30-2004 02:45 PM
sharing big sessions from pc to mac cad2k2 Storage Subsystems 1 06-21-2004 12:17 AM
sharing sessions/drives Chuck Johnson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-16-2003 02:57 PM
Sharing Sessions between PC jayoneill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-25-2003 07:00 AM
