CPU overload
I'm getting the CPU overload message. Yesterday everything was working fine, today I'm unable to use PT, as spikes seems to be ocurring. I,m geting this message on every session, even sessions that were OK yesterday.I even tryed removing all plugins form the sessions but the problem continues.
I need help please
MacBook Pro 2.2GHz Intel Core 2 Duo 2 GB 667 MHz DDR2 Mac OS X 10.4.11 Pro Tools LE 7.4 MBox 2 Pro Lacie 160G external firewire HD |
Re: CPU overload
Has anything changed from when the system worked (e.g OS updates, new software/hardware etc)?
http://www.myspace.com/philogg |
Re: CPU overload
Hi, yes,I remember now, there was some software updates. Updates for itunes, airport, and two more that I can`t remember. Do you think this could be the problem? If so, is here a way to go back? My OS continues the same 10.4.11
Re: CPU overload
From another thread
http://discussions.apple.com/thread....3799&tstart=90 I think the problem was an Airport Extreme update that came out recently. It seems to be causing CPU spikes. If you follow the instructions on that post (as I did) it might solve your problems. Basically you (we) need to uninstall the Airport Extreme update. But that's a tricky thing to do without some additional software. But I'm happy to report that all is well again. And it only cost me, what, about 12 hours. Anyway, Digi, if you're still reading, it might be worth it to have a talk with Apple or at least test this fix and (if it works), spread the news. I see the CPU complaints are multiplying on the DUC. Thanks again for your help and suggestions |
Re: CPU overload
So that should probably be my problem also. I,ll try this solution. Thank you very much Phil.
CPU Overload | Jmissy87 | Pro Tools 10 | 4 | 05-13-2013 10:04 AM |
cpu overload | maxidud999 | macOS | 3 | 03-14-2013 06:48 PM |
CPU overload | jeradbay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-31-2009 06:47 AM |
CPU overload | aldoriba | Pro Tools M-Powered (Mac) | 1 | 12-09-2008 05:25 AM |
CPU overload | Raggi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-20-2005 02:49 PM |
