Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 02-11-2020, 03:17 AM
ChrisThePackRat ChrisThePackRat is offline
Default Bug: Playhead does not stop at the end of edit selection
If I make a selection on a track of more than 500ms, it loop plays as it should.
I would expect a selection of less than 500ms would play once and stop. Instead, playback will occur as if the edit selection is ignored and will continue playing past it.
A similar issue happens during recording. No matter the length of selection for recording, once that section has been recorded the playhead will continue and the recorded section will appear as if it were still being recorded to, even though it's not.
I'm using Normal recording and Loop Playback.
Anyone know what a fix for this is?
Old 02-11-2020, 04:42 AM
peterle peterle is online now
Default Re: Bug: Playhead does not stop at the end of edit selection
the 500 ms thingy seems a recent bug in PT (1sec minimum),
see other threads
Loop playback is not possible when an input is engaged or
a track is armed...
foley artist , soundeditor
Old 02-11-2020, 05:24 AM
amagras amagras is offline
Could be post roll active?
Sent from my SM-N975W using Tapatalk
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 02-11-2020, 07:17 AM
I hadn't seen that, my transport wasn't expanded. Post roll was enabled for some reason, disabling it makes things work as they should.
Thanks!
playhead not jumping to cursor/selection while playing song back christian kuntner Pro Tools 2019 3 06-05-2019 08:58 AM
Timeline selection while playing forces playhead jump geelo Pro Tools 9 5 02-19-2018 02:45 AM
Playhead doesn't move to beginning of selection after update headsup Pro Tools 10 2 12-18-2014 12:39 PM
Edit selection and playhead start Alexander K Pro Tools 10 12 05-30-2013 09:03 AM
Edit on the fly using the playhead fireball Pro Tools 9 2 05-23-2011 07:55 AM
