Old 11-05-2019, 12:55 PM
chrismeraz chrismeraz is offline
Default What is Cut All Automation?
2019.10 added a new shortcut called Cut All Automation.
Is that the same as Delete All Automation? Does it cut all automation from beginning to end of all regions on all shown and hidden tracks?
Why would I want to cut that instead of deleting it? How could it be useful to cut ALL automation and paste it somewhere else?
From the release notes:
Cut All Automation Key Command
A new key command as added to cut all automation.
Opt+Shift+X (macOS)
Alt+Shift+X (Windows OS)
Windows 10
Apollo 8
Pro Tools Native
i7 8700K, 32GB RAM
Old 11-05-2019, 01:17 PM
JFreak JFreak is online now
Default Re: What is Cut All Automation?
should be pretty trivial. cut something to clipboard and paste it from there to somewhere else
Old 11-05-2019, 03:21 PM
henningaround henningaround is offline
The difference is how the breakpoints of your selection in and out point will be connected after the automation in-between has been deleted or cut. Delete and you create a "ramp" from existing breakpoints before and after your selection. Cut and you create new breakpoints at in and out of your selection.
Old 11-06-2019, 01:24 AM
Thanks Henning! That is very helpful.
Also, now I understand that this command does not cut all automation from the whole session - just all the automation from a selected track and portion of the timeline. Thanks!
Windows 10
Apollo 8
Pro Tools Native
i7 8700K, 32GB RAM
Old 11-06-2019, 09:31 AM
leftalive leftalive is offline
You know what? I've been using PT for almost 17 years, and I never knew that.
PC workstation:
Windows 10 Pro
i7 6900K
MSI GTX 1080ti Armor
32GB Corsair Vengeance DDR4 3200mhz RAM
Samsung 850 Pro 256GB SSD (system drive)
Samsung 850 Pro 1TB SSD (sample drive)
MyDigitalSSD BPX 480GB M.2 (work drive)
2 HGST Ultrastar 4TB drives (backup)
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Old 11-06-2019, 09:39 AM
Made my day! Pleased to help :)
Old 11-06-2019, 01:47 PM
onosendai onosendai is offline
That's a great question and it made me learn something new. @henningaround thank you for the answer.
i7 5820K, 32GB | Windows 10 Pro, PT 2019.12 Ultimate | RME FF802
Old 01-01-2020, 11:41 AM
bagok bagok is offline
After the selection cut process, the automation line is still there and if you move the volume fader, it goes back on line. is there a way to clear all automation ?
Old 01-01-2020, 03:14 PM
You can clear all automation for a selection by clicking edit/clear/all automation
Old 01-02-2020, 06:01 AM
amagras amagras is offline
The key word here is "selection", the command only works in the segment of the track you have selected. To delete automation from a whole track you have to do this but instead of selecting all the tracks in the session just select the track in question:
https://youtu.be/R9F8gxjLfg0
amagrasmusic.com
difference between MIDI automation and Audio automation on Instrument Track? mariam Getting Started 5 04-28-2016 03:55 PM
Import automation plug-in automation from an outside source? idrejected Post - Surround - Video 0 07-06-2015 02:56 PM
MIDI Automation to Audio Track Automation BBKBB Pro Tools 10 6 11-28-2012 01:56 PM
Protools Automation to AAF Media Composer Automation TommyT Pro Tools TDM Systems (Mac) 1 08-10-2011 01:40 AM
Convert MIDI automation to audio automation jnash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-21-2010 03:28 PM
