Old 02-16-2020, 09:21 AM
OAG OAG is offline
Default Anybody got S1 and Dock working with Ableton?
I have an S1 and a Dock (with tablets on each), and while I can get the Dock to show me all the tracks in my Ableton project, the S1 will only show me 1-8, and won't bank up or reflect any higher selection I make from the arrangement window or from the Dock (which communicate fine with each other).
I've followed the setup as far as I can see.
In Control Surface, I have Mackie Control set to Port 1 (input and output)
And Mackie Control XT set to Port 2 (input and output)
In the Midi Ports section, I have ports 1 & 2 input and output enabled for Track and Remote.
I have dragged Ableton to the System Prefs Eucon window and enabled midi control via Mackie on ports 1-4.
I am running Ableton 9.7.7, but I doubt that anything would have changed in Mackie protocol between 9 and 10.
Anybody made this work?
Thanks.
Old 02-28-2020, 07:05 AM
OAG OAG is offline
Default Re: Anybody got S1 and Dock working with Ableton?
I'm assuming not?
Old 02-28-2020, 08:56 AM
basehead617 basehead617 is online now
Ableton isn’t EUCON is it?
Old 02-28-2020, 08:14 PM
mattrixx mattrixx is offline
No it isn't, however, you are supposed to be able to use it in MCU emulation mode.
I had mixed success with this over the last couple of years and Eucon versions.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
Dock Stopped Working dalonso66 Avid S1, S3, Dock and Control 3 04-25-2019 06:21 PM
Attention/Selected Track not working on dock feakerboo Avid S1, S3, Dock and Control 10 02-12-2019 01:28 PM
Can't get my Mix working with Ableton on Win7 please help! pat_00 Artist Series 3 06-24-2013 07:29 PM
Ableton rewire not working 4 seriousness djmichaelwenz Windows 5 11-07-2012 09:15 AM
002 Rack not working in Ableton Live hellofader 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-29-2011 11:44 AM
