#21
Re: Pro Tools Maximum number allowed of latest MOTU Express 128s is 7 ??
Just a shot in the dark here, but there used to be some sort of limit of ten MIDI devices configured in Windows. Korg controllers used to have an issue with this so Korg has a package of USB driver utils to remove any old or unneeded. Since the MIDI code in PT goes way back, it too might be subject to old limitations. In the Korg package there is an app Uninstall Korg USB-MIDI Device that lists the ten allowed MIDI devices (you can also uninstall any device as an option). In the Windows MIDI config those slots may be occupied by devices that were previously configured, but no longer there. They show up as corrupted if the driver is not present and can be removed. See if all 8 of your MOTU devices show up in the Korg app. If not, you can remove devices and the 8th should take an available slot when plugged in. Don't know if that all makes sense, but the Korg tools are here: https://www.korg.com/us/support/down...er/1/285/3541/ and create a system restore point before removing anything.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 Last edited by ChuckS; 02-08-2020 at 05:00 AM. |
#22
You can however cut the midi cable in half and solder regular XLR connectors to it, effectively making MIDI adapters and using regular mic cables for your MIDI gear. You did know that only three pins are actaully used, didn't you? The three in the middle are used, while ones on the edges of the DIN are not. The middle pin is ground and the ones next to it carry signal and as long as you solder everything the same way you can replace your clunky midi cables with standard mic cables and leave the DIN connectors always plugged in. With standard cabling, a patchbay is also very much more convenient.
#23
Cool. However HDX2 would be enough for 128 inputs.
#24
~Will |
#25
But what do I know, I even hate the idea of having more than one master keyboard in a studio, maximum of two keybard on stage. You need to be an effing Jordan Rudess to have more Even having half a dozen synths powered up and ready to be played would take way too much space IMO so I'm just going to accept that I do not fully understand the problem
#26
I realise this, but maybe not enough voices.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
#27
Per card, voice count is 256/128/64 depending on your session sampling rate (48/96/192) -- currently up to 768 voices with three cards. We are still expecting Avid to release HDX voice upgrade that they tried last year but have not yet released. Maybe with official Mac Pro support? With that said, HDN already has 384/192/96 voices with up to 768 voices with extra cost voice packs.
#28
~Will |
#29
A wall of Genelecs would be another story. That disease I have had for decades already. Currently 7060B sub and five 8040B satellites.
#30
HDN is of zero use to me as it is 64 ins max and relies on the cpu which can not handle the sort of buffer I like working at. You don't like walls of synths and you don't like ultra low latency and think 256 buffer is OK.. so.. we'll never agree, let's just leave it at that.
Upgrade: You Have Reached The Maximum Allowed Activations For This Serial Number | [email protected] | Eleven Rack | 9 | 10-06-2018 03:57 AM |
Maximum Allowed Activations | MyerzMedia | Eleven Rack | 19 | 02-17-2014 07:59 AM |
Maximum Tracks Allowed/Pro Tools Mix System | unseen33 | Pro Tools TDM Systems (Win) | 1 | 02-15-2007 08:14 PM |
Maximum number in this Pro Tools Config. | Kris75 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-24-2006 05:55 PM |
What's the maximum no of plugs allowed? | K.B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-05-2004 07:50 PM |
