Avid Pro Audio CommunityHow to Join & Post Community Terms of Use Help Us Help YouKnowledge Base Search Community Search Additional Resources |
This canīt be normal! when PT reads plugin automation during playback it changes the "upload changes" arrow into green (e.g. something has changed). But it was only an automation read, not an auto-write.
It does not happen with track automation (vol, pan etc) only if you auto-enable a parameter of a plugin. Tried it with Air VIs Air plugins and Avid EQ7. This is not the correct behaviour isnīt is? Makes no sense! http://protools.ideascale.com/a/dtd/257559-3779
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 8GB RAM ProTools 2018.12 Digidesign Command|8 macOS Mojave MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise Last edited by jeffro; 04-12-2017 at 09:29 AM. Reason: Added link to the bug report. |
can someone chime in please and/or confirm this bug?
Itīs quite urgent because this bug results in CC conflicts when collaborators work at the same time (both "update" the track with only playing back the track). Thanks
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 8GB RAM ProTools 2018.12 Digidesign Command|8 macOS Mojave MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Does really nobody use CC? Or even care about? Avid?
Hi!
Can someone confirm that plugin automation read-outs lead to a "CC change" so that the upload arrow of the given SHARED track goes green? 1. create a track 2. insert any plugin 3. make an automation of any parameter of the plugin 4. upload/share the track 5. play the automation now the green arrow which shows changes to upload is green, but it shouldn't!
Yes many indications on DUC are that few people use or care about Cloud Collaboration. You are at the bleeding edge here... and it looks like you blood that is flowing.
I would hope that Avid Customer support is super-responsive to folks in your situation willing to play with these new features. Did you try contacting them? Maybe Jeffro or others here can escalate a support case. Yes I know phone support from Austria must be a total pain, but you could open an email support case. I pinged a DUC moderator to see if they can get you help from support. Last edited by Darryl Ramm; 12-18-2016 at 12:40 PM. |
Hey guys
I have escalated this thread to Avid support and will await a response from them. I don't know anyone who uses CC so I can't help you there unfortunately but Avid themselves should most definitely be able to help ![]()
Best Regards Christopher South Side Music Group WEBHOME SOUTHSIDEPUB #Nothing Breaks Like a Heart Eagles may soar, but weasels don't get sucked into jet engines |
Thanks Christoper, I was about to do the same. I, like you, don't use CC. So I can't be much help here either.
~ tom thomas Formerly hobotom Pro Tools Ultimate 2018.12 HDX HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
Thanks guys! really appreciate it!
well, everyone with 12.5+ can create a CC Project in PT and click the "share" button (as described) and see what the upload arrow does. you donīt even need another collaborator.
Hey Jeffro! Any news? I've found people with similar problems in the AiR forum. But no solution yet.
Cloud Collab bug with plugin automation | clausiii | Pro Tools 12 | 2 | 12-09-2016 12:15 PM |
Pt 12.5 cloud collab says my projects are used up but i havent used any yet | HALO1THEGREAT | Pro Tools 12 | 2 | 05-09-2016 04:51 AM |
Removing Application Manager and Cloud Collab? | jjnssn | Pro Tools 12 | 2 | 05-01-2016 12:35 PM |
PT Cloud Collab Webinar 3/15 | Tom Graham | General Announcements | 0 | 03-04-2016 10:46 AM |
