Converting analog video to digital.....
Any of you done this...convert VHS or Super8 video(analog) to digital for editing purposes?
I was talking to Bastiaan(who's a pro) about a program I saw called Dazzle... looks pretty good, but do any of you know of any alternative choices? thanks, Roy
rh music |
Re: Converting analog video to digital.....
Hey Roy
I think you just need a decent video capture card. You just plug the video in and press record on the computer. The card will come with software.
http://www.oneearthproductions.net |
You can also try a video digitizer, which will probably come with its own software as well...
OK thanks, Mark...(I had just sent you an email [img]images/icons/wink.gif[/img] ) I'll look into it. The Dazzle converter is an analog plug interface...looks similar to a small cd player (to me). A card will be even better. [img]images/icons/wink.gif[/img]
rh music |
Pinnacle Systems
Dazzle ATI ADS Irez These all have their ups and downs. Are you planning on going digital anytime soon? If you are you can usualy use your digital camcorder as a gateway to capture your old analog stuff. Food for thought! You could find a nice digital camcorder on ebay right now for under $500. [img]images/icons/smile.gif[/img]
WOW! What is that a .38? 38, 39 what ever it takes. |
rh music |
Talk about fast!!!!!
Also check out Matrox... their capture stuff is A-OK, GI.
Would you have any idea? I really appreciate this info... [img]images/icons/wink.gif[/img]
rh music |
What do you mean both are digital? Digital 8 Is just sony's answer to "break-in" the Digital video format. It'll play standard Hi-8 tapes too, as well as record to them (as opposed to Mini-DV or DVCAM). I would go for the Digi8 far before the standard Hi-8. It will yield higher quality and the recorded material wont be as fragile as standard Hi8 (not to mention hi8 has been on its way out for a couple years now). If this was the case, just get yourself a firewire card and capturing will be a breeze. What is the source format your coming from? Are you going to record the material on the new camera or do you already have it on existing tapes? If so...what format?
PT9 / FW800 compatible analog/digital video conversion box? | glankrudolph | macOS | 0 | 09-25-2012 03:42 PM |
Converting to Dolby Digital AC-3 stream? | ivolino | Pro Tools 9 | 5 | 11-25-2010 08:31 PM |
OT: Video: convert Analog or new Digital ? | rgriff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-06-2006 03:06 PM |
Best method for Converting Video to Quicktime? | TMS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-02-2006 03:37 PM |
analog to digital to analog | major_thom | Tips & Tricks | 5 | 09-19-2001 04:02 AM |
