2 MIX Core cards...
Is it possible to put 2 Mix Core cards (and 2 Mix Farm, 2 DSP Farm cards) in the same exp chassis?
I'd like to have more processing power. I could have a deal for 1 additionnal Mix system (Core, Farm+DSPFarm) so I would double the processing power(almost). Thanks for the replies. |
Re: 2 MIX Core cards...
You can use the additional Mix Core because that will show up like a Mix Farm card but I'm not sure about the DSP Farms. I think you should be just fine but you might wanna take a look at the compatibility docs to see if they say anything.
- Jason |
Looks like it will work then.
- Jason |
The only thing is that this "deal" is not evident to negociate. I mean this is not easy to find the value of this pack(Core, Mix Farm, DSP Farm) on the internet. I live in Canada(Québec) so locally the market doesn't reflect necessarely the US market. Even knowing that this Mix system is now obsolete (meaning that it is no more pushed by Digi). Any help on this would be appreciated |
I don't know if this helps, but here is the US, that package would sell between $3000 - $3400.
- Jason |
Thanks Vaphoron for this "US relative clue"!
What is the thermal output/heat load of HD core cards and process cards? | yosemitesam | Pro Tools TDM Systems (Mac) | 0 | 10-24-2011 02:39 PM |
prottols core cards mix core to hd pci to hd pcix to hd pce | Filmusic | Windows | 1 | 03-24-2011 04:24 PM |
Mac Pro Dual Quad core compatable with HD pci core & accell cards? | PT8716 | Pro Tools TDM Systems (Mac) | 3 | 06-28-2010 07:35 AM |
HELP!!! running 2 core cards on mix sys & lights on cards??? HELP!!! | A Spooner | Tips & Tricks | 6 | 07-08-2009 06:55 PM |
two mix core cards together ??? | Alécio Costa | Pro Tools TDM Systems (Mac) | 2 | 12-17-2006 07:09 AM |
