Re-Link in PT 11 still broken
can anyone confirm this. As soon as I try to relink files with foreign language letters PT 11 crashes. No Problem with 10.
Re: Re-Link in PT 11 still broken
I think Frank Kruse mentioned PT not being happy when running as English language app on a German language computer. Might check with him as he's in Germany also. It may be some type of localization issue.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
In the meanwhile a friend as "hacked" the PT10 script so we made a launch script for 11 ourselves. It's actually pretty easy. Show packet content. Locate the script und replace the PT10 by PT11. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Try these
As downloaded from Google Search PT 10 - https://dl.dropboxusercontent.com/u/...N%20OSX-DE.zip As modified to open PT11 instead of PT10 - https://dl.dropboxusercontent.com/u/...N%20OSX-DE.zip Haven't tested whether the language change works but it should do. C Code:
do shell script "defaults write NSGlobalDomain AppleLanguages '(en,de,fr,es,it,pt,pt-PT,nl,sv,nb,da,fi,ru,pl,ja,ko,zh-Hans,zh-Hant)'" do shell script "open -a '/Applications/Pro Tools.app'" delay 1 do shell script "defaults write NSGlobalDomain AppleLanguages '(de,en,fr,es,it,pt,pt-PT,nl,sv,nb,da,fi,ru,pl,ja,ko,zh-Hans,zh-Hant)'" Last edited by C; 09-24-2013 at 03:22 PM. Reason: to show the script source |
I don't believe this answers the question by the OP however. Which was about foreign language files names rather than foreign language interface, correct?
Open the folders inside the package content. There's a script file in a sub-folder which you can open in the OS' script editor.
I can post some screenshots later today. But again, this as nothing to do with the OP's issue. Just wanted to clarify posting #2. Frank.
True this has nothing to do with the problem. I am running PT 11 in german.
Just for tests so far, because of couple plug ins still not available and other issues. The above stated one one them. foreign language letter are alway a bit problematic when exchanging AAF files. Media Composer messes up the names, but keep the IDs intact. So normally you just have to manually relink stuff based on the ids and everything is fine. But PT 11 always crashes if you try to do just that. 100 % of the tests. On different AAfs from different post houses. |
Just to complete the language script hacking topic. This is what you need to open and edit:
open avid language skript package. then go to: /content/Resources/Scripts and open main.scpt and change the "do shell script "open -a...." line to the path to PT11. Usually that would be "/Applications/Pro Tools.app" (exact lines are in C's posting.) Frank.
Many Thanks !
Download link broken | Peterjk | Pro Tools 11 | 3 | 05-10-2014 01:57 AM |
10.3.7 download link broken | jdphillips73 | Pro Tools 10 | 6 | 08-31-2013 11:42 PM |
Pro Tools 10.3 - Link Broken | smpkeys | Pro Tools 10 | 3 | 09-18-2012 11:50 PM |
