Old 04-10-2009, 10:32 AM
stainless stainless is offline
Default Output to a Buss or send to a buss
probably a pretty elementary question- when would it be more advatageous to keep the tracks output to analog1/2 and take a send to a buss, rather than just sending the output to a buss?
or would take a send while keeping the 1/2 out be akin to duplicating a track and using one "dry" and treating the other?
sometimes I think I make more work for myself....
and a pleasant Good Friday to you all!
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc
Old 04-10-2009, 03:06 PM
Sven62 Sven62 is offline
Default Re: Output to a Buss or send to a buss
There should be more knowleageable responses to this than mine.
But, for me, I use Sends to bus delays and reverbs. Output to a bus/Aux track in order to group multiple tracks (like drums). Output all your drum tracks to one Aux track labelled "Drums". Then you have one channel/fader for drums..... then use a Send to reverb/delay.
Old 04-10-2009, 03:48 PM
andyj4308 andyj4308 is offline
Snap. I'll also use Ouput bus/aux to bounce tracks.
Old 04-10-2009, 10:26 PM
I will almost always leave the drums assigned to L/R and add aux sends to feed a stereo bus with a compressor(choose wisely to avoid latency induced comb filtering). Both BF76 and the Waves SSL compressor work great for this.
Old 04-10-2009, 11:57 PM
danander11 danander11 is offline
Hmmm... I'm a bit drowsy right now but I want to make sure I understand...
You are creating a stereo (or two mono) AUX channels and sending the drum signal to them, then compressing it? then blending the two at the master?
I'll do this for delay, reverb, etc... but have never thought to use the same technique for compression.
What is the benefit of going this route? (I'll be trying this out right after a nap).
MANY thanks!
Peace!
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 04-11-2009, 04:28 AM
Phil Ogden Phil Ogden is offline
MANY thanks!
Peace!
Done correctly, parallel compression adds 'body' to the sound without squashing the life out of the dynamics.
To return to the original post. One way to look at it is to use sends when you want to vary the amount of 'processing' undertaken on the audio by adjusting the sends level.
Bussing track outputs is more appropriate when you're applying processing uniformly and globally.
http://www.myspace.com/philogg
Aux buss path going to wrong buss? [email protected] macOS 3 10-10-2013 08:50 AM
shortcut on putting buss output on several channels at once. broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 02-08-2008 08:43 PM
Dithering when recording buss output to track BackAtTheLab Pro Tools TDM Systems (Mac) 9 09-22-2006 01:50 AM
Output Buss not working HELP!! *DELETED* liquid002rw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-16-2005 09:51 AM
how to show your send levels in buss section ? mersisblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 04-22-2004 12:02 PM
