Playback Engine setting affects XForm rendering time?
In the "Playback Engine" , there is a setting called "Host Processors".
As far as I know that setting has to do with the number of Processors that will be utilised for RTAS processing. But does it also affects the number of processors that will be used when rendering for elastic audio (XForm)??? Does anyone know? |
Re: Playback Engine setting affects XForm rendering time?
Not positive, but I would expect it to have some effect on any process inside PT. The trick there seems to be, leaving enough cpu OUT of Pro Tools to handle "behind the scene" processes for the OS).
Ok, just passed some tests.
Opened an empty project, no plugins, just imported a wav file. Set the playback engine at 1 Processor, limit 40%. Then pitched +1 the wav with Xform. Took 1:42 to complete the render. Afterwards changed the playback setting at 4 Processors, limit 95%. Then pitched +2 the same wav with Xform. Took 1:42 to complete the render. To summarize, the playback settings, have nothing to do with Elastic Audio rendering. |
Hardware Playback Engine size defaults to the lowest setting in PT 10.3.3 | ronstephens | Pro Tools HDX & HD Native Systems (Mac) | 4 | 03-12-2013 02:19 AM |
Optime playback engine setting for Ezdrummer | Recon66 | Pro Tools M-Powered (Win) | 0 | 12-15-2012 12:47 AM |
What's best setting for optimum playback engine performance in pro tools 10 | shamanrock | Windows | 9 | 12-01-2011 05:16 PM |
Help Setting Up Playback Engine | hearttimes | Pro Tools TDM Systems (Mac) | 1 | 08-03-2007 05:45 PM |
Playback engine every time... | GW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-13-2003 11:01 AM |
