Old 06-09-2023, 12:37 PM
orchetect orchetect is offline
Default 2023.6 Bug: 'None' Marker color is not saved
As of Pro Tools 2023.6.
Bug #1:
1. Create a Ruler Marker and/or a Track Marker
2. Set the marker color to None (by highlighting the marker and clicking the None button in the Color Palette window)
3. Save the session
4. Close the session
5. Reopen the session
The marker color is restored to the default coloration instead of 'None'
Bug #2:
There is related issue where if you open the marker editor window (Edit Memory Location), there is no option to select Default or None as a color. If the marker color was set to None before opening the editor window, it will wrongly auto-select one of the colors and apply that color if you click Ok.
UPDATE: Bug is filed on Avid bug tracker with # PT-307058
Old 06-20-2023, 03:05 AM
mbuz mbuz is offline
Default Re: 2023.6 Bug: 'None' Marker color is not saved
Same problem here, PT Ultimate 2023.6 on Windows 10
Marco Buzz
Old 06-20-2023, 09:05 AM
DigiTechSupt's Avatar
Hi there!
I saw the case you opened, this has been escalated. Please check your Email for updates (Case 04642405)
Thank you,
-Tope
Avid Audio Tech Support
Support FAQ
Old 06-20-2023, 09:08 AM
3. Save the session
There is related issue where if you open the marker editor window (Edit Memory Location), there is no option to select Default or None as a color. If the marker color was set to None before opening the editor window, it will select the first color (purple) as a fallback and apply that color if you click Ok.
A case has been created for you as well (Case 04642586)
-Tope
Support FAQ
Old 06-29-2023, 09:41 AM
Bug # PT-307058
Insert Marker Slot broken in 2023.6 off the wall Pro Tools 7 06-09-2023 09:17 PM
2023.6 keyboard shortcut for Track marker Macsearcher Pro Tools 1 06-09-2023 05:52 AM
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
saved copy in >> cannot read session - why is it saved as alias file? [SOLVED] kindkind Pro Tools 10 4 01-30-2016 12:42 AM
Trying to set bar/beat marker, tempo marker won't conform maitredebas Pro Tools M-Powered (Win) 0 07-31-2009 07:31 PM
