Go Back   Avid Pro Audio Community > Pro Tools Hardware > MBOX Studio
Old 05-10-2023, 10:35 AM
tomhartman tomhartman is offline
Default Help..Not Getting Loopback..
I use this daily with PT to capture audio off iTunes or Youtube with zero problem. Today I went to do this and no audio is getting to PT. Can someone look at the screenshot and tell me what dumb thing I'm missing? I hear the audio in my phones but signal is not getting to PT. Thanks for any help.
Old 05-10-2023, 10:59 AM
DigiTechSupt's Avatar
Default Re: Help..Not Getting Loopback..
Hi there,
Are you using the same computer to capture the audio? or are you using a different device and connect the input via bluetooth?
-Tope
Avid Audio Tech Support
Support FAQ
Old 05-10-2023, 11:04 AM
Originally Posted by DigiTechSupt View Post
Hi there,
-Tope
Yes. I do this daily with no problem ( I mute the PT audio track recording the loopback). Today there is just nothing showing on the meters of the track.
UPDATE: I just tried it using bluetooth via iPhone and PT receives the audio fine.
Old 05-10-2023, 03:37 PM
Have you opened the utility menu in the Control software to enable Loopback? If you did previously, I have had that setting not stick once or twice so its worth checking(its the little "gear" in the upper right corner of the Control window). It also only works with a certain set of inputs and I can't remember which(but I think it was ADAT 1&2). My rig is dead at the moment
Old 05-19-2023, 08:50 AM
JDubz70's Avatar
JDubz70 JDubz70 is offline
Hi Tom,
The first thing I noticed is you'll want to pan the Internal 7/8 hard left and right. Right now they're both up the center. Internal 1/2 are correct.
With Loopback you won't see any input meters in MBOX Control since the signal is being internally looped back. You'll need to create a track in Pro Tools or another DAW and then assign the input ADAT 7/8. You should then be able to see the signal coming in on Internal 7/8 on those ADAT 7/8 inputs.
Hope this helps.
JW
Loopback hrbaltzer MBOX Studio 2 02-24-2023 03:05 AM
What is loopback? Popmeise Third Party Interfaces 4 12-15-2017 01:32 PM
Loopback setup desol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 04-20-2014 05:18 PM
AD-DA loopback shootout - anyone? Righty27 Eleven Rack 3 07-18-2012 11:37 AM
adat loopback uri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-21-2003 11:28 AM
