Old 11-16-2019, 04:27 PM
RTGraham RTGraham is offline
Default Video Engine Won't Stay Disabled
I've just gone from 2019.6 to 2019.10 on a MacBook Pro (running Sierra), with some problematic side effects.
1) For one thing, it now seems impossible to keep the video engine disabled if I open a session containing video. We often separate the workloads to separate rigs, with one handling music / scoring, and a second handling video playback via sync (either satellite mode or else MTC/MMC over a network MIDI session).
So quite often, even though the "music" session contains a copy of the video, we keep the video engine disabled on that machine to avoid wasting RAM since the actual video display is from a separate machine. However, since installing 2019.10, if I open a session with video in it, Pro Tools automatically launches the video engine instead of asking whether I would like it enabled (as would happen in previous versions). So then I have to wait for the engine to launch, which sometimes it doesn't. Which brings us to point 2...
2) Quite often I work while mobile, using a MacBook Pro; and quite often I use a utility to force the machine to run only the integrated graphics chip instead of the more advanced discrete graphics chip, because the MBP's historically have issues with discrete graphics chips overheating, especially when using processor-intensive software like DAW's. Since installing 2019.10, the video engine (which previously worked even with the integrated chip) crashes unless I select the discrete chip.
3) Sessions with video that had previously opened correctly (under 2019.6) now *sometimes* give an error indicating that a codec is missing from the system. But not always. And they *sometimes* open with no checkmark on the video clip (meaning that it's not an Avid-sanctioned format) - but not always.
Has anyone else seen these kinds of issues under 2019.10?
Or is this all fairly unusual and I need to open a support ticket?
Old 06-22-2023, 05:12 PM
Kit67 Kit67 is offline
Default Re: Video Engine Won't Stay Disabled
I'm using 2023.6 on Mac. Everytime I open my project, Video Engine is enabled even though I had disabled it and saved it before.
'The Video Engine reported and error' message when trying to play any video zerothrills Pro Tools 12 10 02-28-2022 04:04 AM
Video Engine Fail "Waiting for the video engine to launch" oscar_wonderboy macOS 5 08-14-2018 01:22 AM
Video Engine not working.. crashing when i load in a video to PT11 sarahsherlock Pro Tools 11 5 08-16-2014 12:35 AM
PT 10HD with MXF Video wants Video Engine? rantanplan Pro Tools 10 2 06-05-2014 09:50 AM
Timecode ruler feature, video track features got disabled . . khan.ae 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-27-2011 01:51 AM
