Old 04-02-2019, 03:36 PM
smokeydan smokeydan is offline
Default Recording late with -ve user offset on delay compensation
I have had an issue today where audio I have recorded has printed late (around 1400 samples late) on the timeline - The performer noticed first, and after a bit of experimentation (recording the click track back into ProTools via the foldback whilst making various plugs inactive/trying different routing etc)
I eventually determined that the issue was that some time ago, I had put a -ve user offset of 1400ish samples on an unrelated audio track (to get a distant ambient/room mic to play back in phase with a close mic.) When I set the user offset to zero, protools records the click just 84 samples behind the grid - which I'll put down to converter delays etc and is obviously far more acceptable (The signal path for foldback monitoring in this studio means the audio is being converted from digital>analog>digital>analog again because of the way the Hearback system is being connected)
This isn’t something I have encountered before, although I regularly use this technique to time align room mics - Is this expected behaviour and I just hadn't noticed before? I can’t find any reference to this in the Pro Tools manual.
Or is it a bug or undocumented change in the behaviour of the delay compensation system - if so, since when has it worked this way?
Has anybody else had this issue?
I’m using a trashcan mac, High Sierra, PT Ultimate 2018.12 (I think!) & a sonnet Chassis with HDx cards
Mac Pro 5,1, 2 x 3.46Ghz six core Xeon, 64GB RAM, Mojave, PT Ultimate 2022.10, H/D Native PCie, Avid Omni interface.
Mac Pro 6,1 12 core, 64GB RAM, Catalina, PT Ultimate 2022.10, 2xHDX cards & UAD Octo PCIe card in Sonnet TB Chassis, 2 x Lynx Aurora 16 interfaces.
MacBook Pro 32GB RAM Catalina, PT 2022.10, UAD Apollo X4
Old 07-16-2019, 02:55 PM
Default Re: Recording late with -ve user offset on delay compensation
Just me then?
Old 08-16-2020, 07:33 AM
Husmas Husmas is offline
Little late, but nope.
Did you ever fix this?
Old 06-15-2021, 03:22 PM
pherzfeld pherzfeld is offline
I had this issue today, over a decade later. Any info?
Old 02-02-2023, 11:37 AM
Honestly, I don't know if its been fixed or not, I just stopped using -ve user offsets!
Old 02-03-2023, 11:19 AM
Need more info before any help. What is the maximum latency on any track? Exactly how are you(the player) monitoring?(IOW, is the player listening to the main mix). Any latency inducing plugins on the master track? I ask because I did plenty of recordings with VI's in PT 2018 and never had an issue(but I run Windows)
-Help- Pro Tools is recording late Joschka Bender macOS 12 04-06-2023 09:28 PM
what to set User Offset for HW insert? Fritz Pro Tools 10 3 09-30-2013 06:50 AM
Recording timing / late recording issue resolved DAWgEAR Pro Tools HDX & HD Native Systems (Win) 0 07-17-2013 09:10 AM
Is the User Offset (ADC) really working?? SD2 Pro Tools 9 5 05-24-2011 07:45 AM
Negative "User offset" ADC numbers possible? Tim R. Pro Tools TDM Systems (Mac) 1 06-19-2007 03:14 PM
