Old 09-27-2021, 03:03 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: Can you confirm this bug; Audiosuite settings
Originally Posted by joachim View Post
Workaround :
Open the Audiosuite Plugins you like, set your preferences (in my case : izotope RX Denoise not set to default "fastest", but to "best"), save as Window Configuration.
Settings will stick.
Denoiser yes, but some others (like RX Connect) will not stick to 'individual'.
I'm always using the window configuration option, but have learned to adapt setting some plugins to clip by clip when I open the session.
Old 11-17-2021, 02:54 AM
deesto deesto is offline
This is still a bug after so many years. Really annoying and no workaround either! I need this every day, and waste so much time setting my plugins settings every time i load any session.
Old 01-30-2022, 07:20 PM
harrydanielsono harrydanielsono is offline
I'm also having this problem with Audio Suite.
If I select "create individual files" and "clip by clip", then "mono mode" is automatically selected.
If I then select "multi-input mode", then "entire selection" is selected automatically.
This is a stereo field processor I'm using, so I can now not do what I need to do at all, but have to spend time on an ugly workaround. I've trying AVID support, but the support window is full of bugs and I can't get any actual support.
Seriously. I want to burn AVID to the ground some days.
Old 04-20-2023, 02:32 AM
Chevron Chevron is offline
It seems you are having the same issue that I am having here in the linked thread below, did you get it sorted or find a workaround?
https://duc.avid.com/showthread.php?...=1#post2669161
Pro Tools Studio 2024.3| Eucon 2023.11 | Mac OS 14.3.1 | Soundflow | Streamdeck | 16" Apple MacBook Pro M3 Max 16 Core 64 GB RAM | 2020 MacBook Pro 13" M1 16 GB RAM | Hackintosh i9 9900KS 32 GB RAM
audiosuite: I Messed up. How do I come back to earlier settings? chavernac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 03-30-2010 11:17 AM
7.2 AudioSuite Bug, settings, pilot error? RobMacki Pro Tools TDM Systems (Mac) 0 11-03-2006 04:51 PM
Save Audiosuite Gain settings Karl Engel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-23-2006 08:09 AM
Copying plug settings to audiosuite mobilemac'nstrat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-25-2004 12:42 PM
PT's 5.1 wacky audiosuite factory settings macguy Pro Tools TDM Systems (Mac) 1 04-19-2001 06:59 AM
