Drag and Drop issue from Finder into PT 11
PT version:11.3.1
OS version:10.8.5 I import the wave file from Finder,when I check the Preference-Processing-Import Automatically Copy Files on Import,then will have the issue.when I uncheck it,it's normal. do you have any suggestion? |
Re: Drag and Drop issue from Finder into PT 11
you have REX and ACID files ONLY checked .. All Files seems like what you need ... if you are trying to drag and drop a Wav file ..
Question updated.
if I check the "Automatically copy files on import",PT 11 will not import the audio file. if I uncheck it,PT 11 works. but I really need the function,PT 10 is normal. any suggestions ? |
Is there any suggestion?
there is 200+ view,only one post.
Drag and drop issue | yanos | macOS | 1 | 02-16-2015 02:51 AM |
Drag'n drop issue | yanos | Pro Tools 11 | 0 | 12-10-2014 05:06 AM |
Timestamp Lost when drag and drop from Finder | Irl Sanders | macOS | 1 | 04-23-2013 01:39 PM |
PT LE 8.03 mac drag and drop issue | Bigmuff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-24-2009 12:01 AM |
PT7 - drag and drop from Finder to bin | houser | Pro Tools TDM Systems (Mac) | 4 | 01-15-2006 05:11 AM |
